    May 30 2015
    canada
    p1543 code-throttle actuator signal too low
    just got this code, was doing a 3rd gear pull and car cut out and went into limp mode, epc light came on and im only able to do - 10inhg according to boost gauge. tried a TBA but no luck, code clears but comes back after driving. do i need to replace my throttle body? thanks in advance.
    Aug 30 2007
    nyc
    check tb plug that all gold pins are level... been there
    c5 A6 tip
    this n that
    May 30 2015
    canada
    ok unfortunately im reviving this thread after i thought the problem was fixed. I cleaned the throttle body really well yesterday and it was running good all day so i thought it was just a dirty TB, today after work it happened again so i scanned with vagcom and found two new codes - p0117 engine coolant temp sensor ; signal too low and p1542 angle sensor 1 for throttle actuator ; implausible signal. Does this seem like a bad ecu? I dont have a multimeter so i haven't checked the wiring yet (going to buy one soon) and all the fuses are good, dont really know what to do at the moment.
    Sep 09 2014
    Grand Rapids, Michigan
    Weird question.. But did it rain when this happened? My ecu box gasket(the lower one between the rain tray and part the actual ecu sits in) was leaking and water would leak down onto the plugs underneath my ecu going into the dash. I'd unplug those and look for corrosion.
    May 30 2015
    canada
    yes it was definitely raining a bit around the time this issue started, i pulled the ecu out of the box yesterday to inspect the circuit board for damage and notice a tiny bit of liquid around the screw holes and the perimeter of the board. i will check the plugs going into dash today, thanks.
