Results 1 to 9 of 9
    Established Member Two Rings Cygnets's Avatar
    Jun 28 2016
    07 Audi S4, VW Jetta 1.9 TDI
    Hershey
    07 S4 serpentine belt replacement
    So I have my whole front end in service position atm, I have about 3-4" of room to fennes, but is there any way to get the damn belt on without loosing the tensioner? Because apparently my bolts for it are stripped.
    Help please lol
    Senior Member Two Rings alcatranz518's Avatar
    Jun 10 2014
    Stoneville, NC
    That really sucks to hear, unfortunately to my knowledge there isn't.
    The sole purpose of the tensioner is what you are trying to work around. This probably isn't what you want to hear but the tensioner will have to be replaced, and if the stripped areas are on the block face you will have to retap them in order for this to work reliably. I know it isn't great, but because of what it takes to get to that point it should only take an extra hour to fix it at most (which I can speak from experience you will spend twice if not 3x's longer trying to find a work around). Additionally, if you work around it, it may cause future issues or will just have to fixed next time.
    The tensioner isn't terribly expensive and you probably can get one locally if you are in/ near more of a larger city.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    are you talking about the threads or the head of the bolt ?
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    you have to loosen the tensor, if your old belt has lost some of the inside ribbing it will be a few mm larger then a new non stretched belt. i think the tensor moves like 3 mm when tightening alone
    i would tell you to go to auto zone or advance they have extractor tools sometimes you can rent or you can buy them then just get the bolt if still good, or order all new tensor its not that bad of a price.
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    There are 2 bolts holding the tensioner to the block, and one which is used to hold the pulley at the correct tension. If that one is rounded off, just unbolt the entire unit and let it drop off. Then you can remove the set bolt on the bench, or replace the tensioner.
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    I'm going to leave this here... Easiest bet to get at stripped bolts on the front of the block is to bite the bullet and take off the ENTIRE front end. http://www.audizine.com/forum/showth...7#post11129007
    07 RS4 | 03 M5 | 24 RS6p
    Jun 28 2016
    Hershey
    I bit the bullet and took the whole front end off. Had to buy all new fluids, but hey she needed a bit of fresh fluids.
    Surprisingly everything came off correctly and went back on with no problem. Autozone messed up and gave me the wrong belt, but after the new belt it was amazingly easy.
    Thanks guys!!
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    wow that picture looks kinda weird
    it's mirrored
    Veteran Member Three Rings mark_ma's Avatar
    Feb 25 2015
    Denver/Colorado
    Quote Originally Posted by jakeoboy67 View Post
    it's mirrored
    its the UK version...
    Le build thread of mark_ma,
    Instagram: @mark_b6s4, Youtube: markb6s4
    4 wheels, 8 pistons, two mufflers , ultra light weight seat warmers, see through windows, carbon fiber turn signals, wireless key fob, photon reflecting side mirrors
