Originally Posted by
AKPS4
Have dealer Check it out. I had similar issue and found I had a very minor leak under the super charger. Engine was so hot that it evaporated the coolant before it ever leaked anywhere. Would have never known if I didn't open the hood and do my own oil change.
I had a leak under the SC as well - for 3 years it was minor enough that I mentioned it at every service, but they pressure tested, etc and found no leaks. I just kept adding coolant...
Then it finally got bad enough in Nov/Dec last year that I started noticing coolant puddles on the undertray, and occasionally would get some belt squealing on startup. Coolant was running out off the top of the engine under braking after pooling there. They SA said they found a lot of dried up coolant on the top of the engine.
They replaced the thermostat and one small pipe/hose and some seals. It was better good for about 5 months, but then the coolant level started back down... Right now the level is below min when cold again, so I'm taking it back in Tues before my warranty is up.
