Originally Posted by
Audibot
You can bleed the ABS pump via VCDS. Just need to go into the module, select Output Tests, and follow the prompts.
Funny enough a few months ago I replaced my rear brakes, and somehow the fronts ended up with air in them. Took a lot of 2-man bleeding to get an extremely solid pedal!
I tried that and my vag com keeps timing out. really strange..
themadscientist
I've never had to run the pump when using a power bleeder. what psi are you using the bleeder at? If the lines were disconnected for a while, you would need to start bleeding at the master and work your way down.
I didnt realize you can bleed the master? how do you go about that? I am running the brake bleeder at 10-13 psi
seanf86
I had a shitty soft pedal when I first installed C5 A6 ATE calipers on my wifes B6, after bleeding and bleeding I took it for a drive and jammed on the brakes and got the abs to activate and the pedal firmed up after that.
I can't remember the exact reasoning but my college auto instructor told us about the seal not sliding down the caliper piston after a brake job so the seal would stretch and pull the piston back meaning more pedal travel until contact, a good sold romp on the pedal would force it to move and it would stop pulling the piston back so far and the mushy pedal would go away.
I was thinking about going to a sandy parking lot near buy and jamming the brakes. I have been driving the car and the pedal cleaned up a little bit but still not where I want it/ where it was before..
My other idea was possibly bleeding it with the car on.. Since I can get a nice hard pedal with the car off
