Results 1 to 6 of 6
    Jul 19 2016
    canada
    Question audi Q5 starting problem
    hi
    bought a salvage Audi Q5 2009 it wont start from battery. battery is completely full every thing turns on and when try to start it make big click sound and when i connect jump cable under the hood it start any one know if there is any sensor or any thing i have to change cuz it was in accident thanks
    Jun 27 2011
    Quote Originally Posted by eshan View Post
    hi
    So it doesn't start with the battery, but when you connect jumpers it does start? That would be your battery, bud. Remove the terminal clamps and clean any corrosion off and try again. If it still doesn't start then your battery is toast.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 19 2016
    canada
    no it deosnt start from battery. it only start from connecting jump cable at under the hood .
    Jun 27 2011
    Um...see my post above?
    -CP
    2017 Q7 3.0t
    Established Member Two Rings RUBZERK's Avatar
    May 20 2014
    Lancaster, Pa. 17602
    Have you tried jumping by connecting directly to the battery instead of under the hood?
    If it starts, then it's the battery. If it doesn't, then idk.
    Jul 19 2016
    canada
    i found the problem my Battery Fuse Overload Protection was blown which happen in time accident part number 4F0915519. for now i just connect straight without fuse so lets hope nothing overload thanks every one for help.
    https://www.youtube.com/watch?v=fLZQc9SuAc4
