Results 1 to 34 of 34
Thread: Intake question
    Established Member Two Rings roydle's Avatar
    Oct 25 2015
    FL
    Intake question
    I wanted to buy the Eurocode Trufit Intake as it is one the quietest intake but it seems they are not selling it anymore. I like the light supercharger whine. Is there another intake similar as the Trufit? APR, ECS, RocEuro, USP make to much whine for my taste. Is the silicon throttle body Inlet Hose from 034 and a cylindrical performance filter will be the same as the Trufit intake? Feedback please
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Intake question
    check awe intake
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    I have an ECS. Fit and finish is great. SC whine is noticeable but tamable.
    I'm actually thinking of making a switch to the apr stage 1 though.
    It is a little easier to swap it out for dealer visits.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Loe is running the setup you're suggesting and he said it was real quiet with minimal whine. I'm running the 034 silicone intake tube, open with an inverted cone filter on it and it screams...so you could go either direction with the intake tube.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    AWE S-Flo is almost identical to the Trufit. Silicon tube and high flow filter. That's what I got when I couldn't get the Trufit.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Oct 25 2015
    FL
    Thanks all for the feedback. Seems AWE is the way to go.
    Nov 06 2015
    NY/RI
    I believe the one I have is eurocode, was thinking about selling it lately too if your interested. Shoot me a pm
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Anyone know how the sounds of the AWE S-FLo (not carbon) is compared to the ECS full carbon intake? The ECS is quieter than any of the open element systems I have heard, but wondering where S-Flo fits in there. I like the idea of getting rid of the OEM baffles in the tubing and putting a less restrictive filter on to get solid performance with an OEM look.
    Also, performance wise, all of these are relatively similar and most notable when paired with a tune I would imagine.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Oct 08 2015
    Quote Originally Posted by XxSullyxX123 View Post
    I have the s-flo. The s-flo is very very quiet compare to any open intakes. You are only able to hear a noticeable sc whine when you go >75% throttle and above 4000rpm. Even so, the whine is not loud at all.
    Current: '18 M3 ZCP
    Jul 20 2012
    Quote Originally Posted by yjypm View Post
    +1. Don't expect whine from the AWE S-Flo. I went with it as I mainly just wanted a smoother airflow and a higher flow filter. Maybe I'd hear more whine if I removed the snow screen...? But I'd rather hear my exhaust anyway.
    2013 S4
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    Here you can hear the S-flo intake. It is one of the quietest intakes for the 3.0 engine. You'll get a subtle sc whine on >50% throttle.
    https://www.instagram.com/p/BHnEWYNgaaV/
    For the ECS there is a video on youtube.
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    if the whine is a problem why don't you just get a K&N drop in on your stock air box?
    Senior Member Two Rings JustPlaneChris's Avatar
    Jun 09 2016
    1998 Mazda B4000
    Austin, TX
    Here's a clip of 034 Motorsport intake hose, K&N filter, stock box with the snow screen and the internal air deflector removed. This is not a hard pull, and it's a bit windy, but you'll get the idea.
    From inside the car, it's barely louder than stock. You can hear it if you know what to listen for, and if you've pulled the Soundaktor fuse.
    https://www.youtube.com/watch?v=GJT1OAGnERc
    Chris
    2014 S4 - 6MT | Brilliant Black | Black Optic | Carbon inlays | Alcantara | B&O | CR-15 Strut Brace | 034 Intake Hose + K&N
    May 06 2015
    Minnesota
    I have the AWE S-Flo and I have also removed my snow screen. The resulting S/C whine is subtle and just right for me. The other thing I like about it is when it's time to go to the dealer, it takes all of 5 minutes to remove the AWE intake tube and replace with the stock tube so everything looks OEM. Overall very happy with the result including better low RPM throttle response.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Jun 28 2016
    US
    034 Hose or AWE Hose and an AFE filter and you're good to go. If you ask real nice and under the radar, it's possible to get just the hose part from AWE. ;)
    Despite what the Amazon part fit check tells you, this does fit the S4 and without any mods. I have no idea why their dinky part checker says it doesn't fit. https://www.amazon.com/aFe-11-10121-...=AFE+S4+intake
    Oct 08 2015
    Quote Originally Posted by MN Blue S4 View Post
    I'd spend ten more minutes to swap the filter in case for some reason they replace it.
    Current: '18 M3 ZCP
    Mar 04 2015
    Somers, NY, USA
    Quote Originally Posted by ChrisR14 View Post
    thanks,,i actually have the full carbon ECS intake, and for under hood bling it is great! And compared to others it is quiet, but I still prefer the exhaust sound to the intake....I don't want go back to stock necessarily, given if (when) I go stage 1 or stage 2, it makes sense to have the intake.
    Mar 04 2015
    Somers, NY, USA
    Quote Originally Posted by creativecody View Post
    I'm debating on swapping my ECS for the S-Flo basically for this exact reason. I do really like the ECS intake though. Sounds great and looks amazing. Though the hood is rarely open lol. Also, I can bring my car to the dealer with the intake installed, but would prefer not to. And the AWE is much easier to change than the full ECS.
    Oct 08 2015
    If you want a swap you can pm me because I am thinking to swap mine for an ECS Carbon one. Of course, I'll pay you extra for compensate.
    Current: '18 M3 ZCP
    Jan 21 2016
    I'm selling my ECS one. PM me if interested.
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Have had a APR and a ECS - I prefer the fit finish of the ECS thats on my 2015 now
    APR STG II
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by roydle View Post
    What stage are you currently at right now?
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Mar 04 2015
    Somers, NY, USA
    Quote Originally Posted by Loe View Post
    Loe, what's the difference between going with your intake set up vs. the AWE S-Flo? Basically pretty much the same with the 034 silicone pipe and the Afe filter right?
    Aug 09 2015
    Sarasota, FL
    The aFe filter is an inverted design, but yes they are pretty much the same functionality wise if you pick up the standard S-Flo and not the Carbon version. The AWE has mounting brackets, a nice touch IMHO.
    on a side note, for those like my who want to keep the stock airbox, I recently resolved my collapsing accordion section by drilling 3 quarter inch holes and installing plastic tab in them that expand when you insert the screw in them, so it secures the accordion section to the front scoop in place under boost. A nice $3.00 mod for me, and an alternative until I want to spring for the carbon S-flow that replaces the airbox lid/accordion section.
    Mar 04 2015
    Somers, NY, USA
    Cool thanks for the info. On a stock tune for now, so not super worried about and collapsing yet :)
    I was thinking about standard S-Flo. Just sold my ECS carbon. want a quieter intake and less $$ invested in a part I never see.
    Senior Member Two Rings audis4culver's Avatar
    Mar 07 2016
    2016 S7, 2011 S4, 1985 VW Vanagon, 2015 Q7, BMW 2004 X5 Manual, 1966 Jaguar E-Type
    Georgia
    I have a giac tune and installed a awe s-flo intake (not carbon ) just the silicone tube and filter. I am very sensitive with sounds and cannot hear any whine at all. Later installed an awe touring exhaust.. best investment I have ever made - the sound is simply intoxicating.
    2016 Audi S7
    Mar 04 2015
    Somers, NY, USA
    Quote Originally Posted by audis4culver View Post
    Yea, I didn't love the whine with the ECS, which was also far quieter than other open element intakes I have heard. The S-Flo is probably exactly what I'm looking for. Love the AWE exhaust and it sounds better without the whine getting in the way :)
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I guess I don't understand why people who don't like supercharger noises even bother with an intake? I mean, isn't that the whole point?
    https://youtu.be/YB__RrouHJo
    2021 Audi S4, P34 Intake
    Mar 04 2015
    Somers, NY, USA
    Fair point, although ive read that it is highly recommended to have an intake for max gains once you get tuned. for me on a stock car its kind of worthless I would imagine.
    Dec 03 2008
    2018 SQ5
    For me, an intake was a must. I had never driven a supercharged car before, and had been driving a tuned turbo for many years. This engine was so quiet in stock form that I couldn't really understand what was going on under the hood. Installed the intake first week so I could hear it and understand it. It's like seeing a boost gauge for the first time and understanding how everything you are feeling falls into place.
    Oct 25 2015
    FL
    So I installed the AWE so flo intake. Very quiet which was what I wanted. Wanted LOL. If I want a bit more whine, if I change the silicon tube to a carbon tube (APR or ECS) and keep the stock airbox, will the whine increase?
    Mar 21 2015
    Not by much if any at all if you are using the full stock air box.
    Aug 09 2015
    Sarasota, FL
    One thing that I have noticed is that the 034Motorsports intake tube produces more s/c whine than the AWE intake tube. The 034Motorsports is more flexible and the material doesn't feel as thick, however the tube is bigger than the AWE intake tube aside from the ends where the 034Motorsports tapers inwards because the hose is bigger in the center area and the AWE tapers outwards because the hose is smaller . I didn't take a picture (I should), but I picked up an AWE S-flow intake system (carbon fiber airbox one) from a FL member today and installed it. I may end up selling it and keeping the stock airbox w/ my reinforcement mod, not sure yet, or just sell the AWE intake tube + air filter (the basic "S-FLO") and install the aFe filter + 034Motosports intake tube on the AWE carbon fiber airbox lid/air scoop.
    Mar 04 2015
    Somers, NY, USA
    Just installed the basic S-Flo. Exactly what I was looking for. Very quiet and no loss loss of throttle response you get when u get rid of the stock box. very OEM+ type of a mod.
