Same as much as the latch mechanism. I think there's 2 phillips screws by the warning triangle, then you just have to pop off the stupid clips that hold the inner hatch in place.
Did you notice how expensive the part is? I spent $100 on the latch, then found out the part I really needed was another $125. I was pissed. I wound up buying a used on ebay for $60. Hopefully when I install it here in a minute it works properly
Edit: go ahead and buy a new one. The used one made no difference. Either my car just has something else going on with it, or this used one is also dying. You see it try to move when you hit the button on the hatch, but it just doesn't have the power to fully release the latch. And each time you hit the trunk button after has less effect each time. By the 3rd or 4th try the actuator doesn't even move
