Results 1 to 21 of 21
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    I have ants! (and not in pants!)
    Hey Everyone,
    As the subject states, I discovered today that it looks like I have a small ant infestation. I noticed several ants around the belt-line trim near my light-switch / cluster, it appears they are coming out of the areas where the cluster meets the trim. I am totally stumped how they got in the car, as I do not eat or drink in my car at all. Maybe they snuck through the cracked / vented sunroof that I have been keeping open a lot more lately due to the hot weather?
    Either way, I need them GONE. What's the best way to achieve this (traps, sprays, etc.) that I can lay out and kill them all?
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Apr 15 2014
    Ottawa/Gatineau Canada
    Borax
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Established Member Two Rings seencats's Avatar
    Feb 19 2014
    Enterprise Rent-a-Car
    NYC / Northern New Jersey
    I too had an issue a few years back. I just kept driving and did some high speed pulls but I don't think airflow from driving hits your area of infestation. Ya never know though...I'm sure they won't last long.
    Aug 30 2013
    Rockville, MD
    i had an issue like this in my q7 when I had it parked near some woods for a while. I used bug bombs, it took a few rounds tho. Maybe a combination of borax and bug bombs
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Before you spray anything around, test it on the back of your trim or somewhere. Some of those bug killers (including repellents) take plastic coatings right off.
    I once used some bug repellent, then held my digital cam and discovered that all markings/icons on the buttons on the back of the camera that I touched were gone!
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    I have this issue every time I park my car at my parents house. They crawl from the wheels up and I think they feed on the dead bugs in under the hood but they go all inside the car as well. I usually just deal with them and they die off but I have occasionally had to bomb it. Then vacuum them up lol
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Established Member Two Rings catchuk's Avatar
    Mar 17 2011
    Victoria,BC
    +1 for Borax
    Mar 28 2015
    Quote Originally Posted by catchuk View Post
    +1 for Borax
    FYI, Terro is Borax in solution with sugar so the ants eat it and bring it back to their nest and take the whole colony out.
    Mar 21 2015
    Borax works, mix it correctly and use cotton balls for a day or two.
    Mar 17 2011
    Victoria,BC
    Quote Originally Posted by Kevin C View Post
    Nice, I'll have to try that next time!
    Senior Member Three Rings Powderhound's Avatar
    May 09 2015
    CT/VT
    Totally agree with borax, will be tracked back to the colony, very effective.
    2013 S5 Prestige | Phantom Black | Black Nappa | DSG | Sport Diff | Carbon Atlas
    Mods: Full Xpel, Ceramic Pro, RS Grill, Deval CF lip & diffuser, ECS CF side mirrors, Ecodes, EPL stage 1 ECU & TCU, H&R Street CO, SPC UCA, AWE S-FLO CF Intake, AWE Track/Res. DP, Alu-Kreuz, CR-15, Stoptech slotted rotors, stainless brake lines, 034 engine and trans. mounts, Vorsteiner V-FF 103/Conti DWS 06/H&R DR 5f 10r, Winter: Peelers/Nokian Hakka R3/H&R DRA 20f 25r/WeatherTech
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    This is the best on the market. Im a entomologist at UCR which is one of the biggest entomology schools in the nation. We test alot of these products and this is by far the most effective.
    http://www.epestsupply.com/cgi-bin/s...B#.V55OssllDqA
    Feb 12 2004
    Austin, Texas
    Hey Guys,
    Thanks for all the input so far. So for those that are recommending Borax + Sugar, what is the best delivery mechanism here? Someone mentioned dipping a few cotton balls, and maybe laying them on a paper towel and letting it sit overnight inside the car? Just trying to understand what is the best delivery system here with using the Borax.
    Thanks,
    Asif
    Mar 21 2015
    I dipped the cotton balls in the borax mixture and just let them sit for a day near where the ants were. Changed the cotton balls the next day to new ones and a day later I didn't see one live or dead ant and haven't seen any since. That was 2 months ago.
    Feb 12 2004
    Austin, Texas
    Weren't you worried about it affecting / discoloring the trim? I'm assuming I should at least put a strip or 2 of a paper towel down and place the cotton ball on top of that?
    Thanks,
    Asif
    Mar 21 2015
    ^this was in my house. i left the cotton balls on lids from glass jars
    Mar 28 2015
    Put the bait in the cowl area between the engine and the windshield. The ants will find it... A complete ant trap will work, just leave it in there. No problem if it spills. I have mixed up my own borax solution and found the premixed stuff in the traps works much better.
    Jul 07 2009
    Socal/IE
    Quote Originally Posted by A4orce84 View Post
    Hey Guys,
    Thanks,
    Asif
    Put a few soda cap lids with the cotton/borax or optiguard(what our ant control professor suggests) and just leave them around the car. Would be best to find the nest and treat it also. Opti guard is a clear gel that won't stain and the ants will find it over sugar or similar.
    Mar 28 2015
    Quote Originally Posted by tar View Post
    You do know that optiguard is a sugar based bait that uses Neonicotinoids. Personal experience is that the ants will make a nest in the car in some protected area. Basicly, you have a mobile Uncle Milton's ant farm.
    Nov 24 2014
    DMV
    I had a similar problem this spring after moving into a place near the woods. Before you use chemicals I'd suggest clearing out any brush under the hood/wipers and taking a hose and washing out the area between the trunk and the rear windshield. I found out the ants were mainly coming from that trunk area of my car which had leaves/gunk built up. After clearing that out the ants went away, no chemicals needed. Good luck!
    02 B6 A4 3.0 6MT Sport Package | Kenwood DDX9702S Double Din | Tint | B7 S4 Front Calipers & 345mm Brembo Rotors + Pads | Blauparts "U-Slot" Slotted Rear Rotors + Pads | ECS SS Brake Lines | APR Snub Mount | ECS Short Shifter | BFI Shift Knob | 034 Front Swaybar Endlinks | Lemforder RS4 Outer Tie Rods | SPC Adjustable Front Control Arms | Meyle HD Lower Control Arms
