Results 1 to 13 of 13
    Active Member Two Rings XtremeXiong's Avatar
    Feb 18 2016
    Hampton Roads/VA
    B8 A4 - Help Needed! Dead Car
    Hello all.
    I was wondering if anyone would be able to help me figuring out what's wrong. I was driving around town and was caught at a stop light when my car completely shut off on me. After looking under the hood I found my MAF sensor disconnected and melted by the heat. Shouldn't the car still be able to turn on even without it plugged in (running rough)? It still will let the car go into accessory mode and the battery was just replaced 1 month ago. Any help is much appreciated.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Weren't you looking for the pins for the female connector for your MAF this week? If so, I have to ask what you did? Wires melt from shorts, but I don't think an automotive grade wire in the engine bay would just melt from heat.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    @lambda13 had his melt also. I don't recall whether or not the car ran, but it definitely messed up his ECU. Maybe he can chime in.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Feb 18 2016
    Hampton Roads/VA
    Quote Originally Posted by bakedziti View Post
    Yes, I was looking for the pins for the female connector. I believe it was contacting the HFC or Turbo and the heat from either was melting the plug.
    Audi B8 A4
    -- MALONE TUNING -- EUROCODE HFC--BLACK FOREST INDUSTRIES INTERCOOLER--VMR 710S 19"--CTS INTERCOOLER PIPING--CTS TURBO MUFFLER DELETE--P3 GAUGE--STRAFE FRONT SPLITTER--FORGE MOTORSPORTS DV--CUSTOM EXHAUST
    Jun 26 2009
    Bremerton WA
    The MAF gets gets its power from the ECU. The HFC is also a ground. When a MAF comes unclipped it lands on the cat or turbo. If the power feed melted and contacted the ground you may need to start checking fuses. Likely the ECU fuse is blown and why it won't run. With the MAF disconnected the car will idle perfectly fine, once you start applying throttle and it needs to read the changes in air volume it will sputter badly. The ECU should command the wastegate open to limit boost and possible overlean conditions.
    VMR 710's, APR software, Eurocode HFC
    Feb 18 2016
    Hampton Roads/VA
    Quote Originally Posted by van462 View Post
    @van462 Thanks for the information. I'll check the fuse and report back. Hopefully it is just the fuse and not the whole ECU.
    Audi B8 A4
    Jun 26 2009
    Bremerton WA
    Make sure the pins aren't shorted to one another as well.
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    My MAF wasn't working for months and I didn't have sputtering, surprisingly.
    My 2009 A4 Prem+ Build thread
    Jun 26 2009
    Bremerton WA
    Any update on this, another member has a very similar issue.
    Feb 18 2016
    Hampton Roads/VA
    Hey! So I figured out the issue. When my MAF sensor came unplugged it grounded the MAF fuse when it got melted by the turbo. Replaced it and it fired back up!
    Jun 26 2009
    Bremerton WA
    Thanks for the update, which fuse panel was it located in, driver/right dash, passenger/left dash or truck?
    Active Member One Ring boactionjaxon's Avatar
    Feb 04 2015
    98 bmw m3
    Quote Originally Posted by XtremeXiong View Post
    Was it throwing any codes up on the dash?
    Feb 18 2016
    Hampton Roads/VA
    Hey sorry guys for not responding sooner. The vehicle was throwing a MAF code only. And the fuse is located in the trunk.
