I was driving the other day and the car died as I came up to a light. Tried to start it and it just wouldn't start. I was trying to gas it to see if it helped as I was cranking and it seemed to not help at all, almost like I wasn't even pushing the gas. I got out of the car and unplugged the MAF to see if maybe there was a big air leak and that might have been the problem. Did nothing. I popped the backseat off and turned the key to on, no sound. Tried it a couple times and still no sound. Checked for pressure at the fuel rail and got a little spray to come out. Once I got all of the pressure out, I turned the key to the ON position a couple more times, got no sound from the pump, checked the schrader valve at the rail, no pressure. So I figured it had to be the pump and had one overnighted to me.
Fast forward to today. I came to the car and decided I'd check it out one last time before I started working on it. I popped the lid off of the fuel pump and turned the key to the ON position, fuel pump made a sound and primed. I turned the key off and tried it again, pump primed again. I tried to start the car and it fired right up with a perfect idle. Let it run for about 15 seconds and pressed the gas pedal, car died. So I waited a few seconds and turned the key to the ON position again, pump didn't prime. Tried again, nothing. So about 5 or so times I tried to get the pump to prime and it doesn't activate. It sounds like the pump is the problem. Any advice? I was just about ready to tear into it and change it out.
Just verified that there is spark.
