This is a project car and still needs a little bit to get it completed. Project in the sense that this used to be a Tiptronic Auto transmission and it was converted to a 6 speed manual tranny from Audi A6. Its fairly clean on the inside, the outside is in decent shape, but isn't perfect, front bumper has a small puncture from the previous owner.
What was done:
- A6 Transmission with all other manual equipment
- A6 Rear diff (recently rebuilt)
- New driveshaft
- New front axles
- Air suspension replaced with regular struts (by previous owner)
- New RS4 clutch
- Resurfaced flywheel (more on that later)
- Custom downpipes
- Timing belt kit with all the auxiliary items replaced
- Cam chain seals, valve cover seal and cam seals, all replaced
What's still needed:
- Flywheel
- Brakes need bleeding
- 3 Wires terminated for reverse, clutch interlock and cruise clutch interlock. All wires are pulled, currently the clutch relay is bypassed so the car will start without depressing clutch.
- Brake switch ($15 at costless)
- Some interior assembly, I pulled most of interior out to do a good cleaning, which i accomplished, but haven't assembled all the trim in the back yet.
What you get:
- Pretty much what's described, but I can throw in a bunch of other things from A6 that I parted out.
- Just the motor + manual tranny equal the asking price, so if you want to part it out, you're getting a really good deal.
For photos, see cragslist ad: http://portland.craigslist.org/clk/cto/5705021020.html
