Results 1 to 7 of 7
    Mar 30 2015
    Harrisburg PA
    Q5 Xenon Bulb Replacement can you DIY?
    So here is the situation. One of my D3S bulbs is out on the Driver side of my Q5. I have 2 new factory bulbs I ordered. My question is has anyone changed these bulbs out? Does it require pulling the headlight out or taking the bumper off? I've done a good amount of searching and I've heard horror stories about how big of a pain is the a** it is and the possibility of damaging the leveling feature on the headlight assembly. Audi is saying I can bring it to them and it only takes 45 - 60 mins. I'm not sure I believe them and not sure I want to risk taking it in and getting handed a $200+ bill for labor when I was quoted 60 mins. Do I risk damaging the headlight? or risk getting a 200+ labor bill from the dealer?
    Anyone have suggestions? Thanks for any help!
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Can't help you on to Deal(er) or no Deal(er), but I can show you a pic from inside the assembly.
    Good luck!
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Mar 30 2015
    Harrisburg PA
    Quote Originally Posted by ThunderDent View Post
    Good luck!
    Thanks for the info. I feel like the access panel should be able to be removed without too much effort, but I have been wrong before. I will get under the hood tonight and see what it looks like.
    Senior Member Three Rings AngryQ5's Avatar
    May 05 2013
    15 Kia Rio Lx DD audi q5 2.0
    ny
    I havr personally DIYed headlight bulb when i bought my Q.
    I remember loosening the headlight assembly to slide them out a little bit. To have easier access to the bulbs.
    You might not have to but it was either sliding the headlight or taking the intake off i believe, which i thought removing headlight bolts and sliding it alil out easier
    Sent from my SM-N900V using Tapatalk
    Mar 30 2015
    Harrisburg PA
    Quote Originally Posted by AngryQ5 View Post
    Thanks for the reply AngryQ5! Was the access panel relatively easy to access along with the headlight bolts? How long did it take you!?
    Veteran Member Four Rings spijun's Avatar
    Oct 11 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by AudiSCarbon34 View Post
    Here:
    Removing and installing gas discharge from model year 2013 onwards.pdf
    May 05 2013
    ny
    If your talking about the top plastic cover yes.. tou pull it right ip and theres like 6 plastic screws to take it off ... i belive good 30 min for each headlight.
    Make sure u put light alittle foot long tapes right under the headlight so it doesnt scratch your paint around the edges of the headlight.
    I am talking about the bumper that meets the edges of the headlight assembly.
    I didnt realize but when i was shimmying the headlight to swivel them out i got some minor scratches on the paint.
    Have fun
