Results 1 to 12 of 12
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Strange noise coming front front of vehicle when turning
    When turning left or right, I hear a "muhhhhhh" sound coming from the front of the vehicle. I thought I was low on power steering fluid but all is good there. Also, turning the wheel at a stand still does not reproduce this sound, only when the car is in motion, so I know it's not my PS pump. I don't get any kind of vibrations or other physical feedback when the noise is present. I did a little bit of searching and it could either be a bad bearing or the pistons in the brake calipers not retracting far enough. Anyone know what the heck this is?
    Found this TSB too: http://uberlame.com/a6_tsb/Brakes/Br...w%20speeds.pdf
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    May 17 2009
    Idaho
    No bites eh?
    Current:
    2002 1.8t A4 Sedan
    Mar 28 2016
    I think you are describing the noise mine makes when making full-lock, or near full-lock, turns in either direction. My assumption has been that it's from the differential.
    May 17 2009
    Idaho
    Quote Originally Posted by hilmar2k View Post
    It's present even when not turning near or full lock. Also, I've noticed that there are times where I don't hear it. But it definitely sounds like the sound mentioned in the TSB.
    Current:
    2002 1.8t A4 Sedan
    Feb 11 2016
    Worcester,MA
    I'll go ahead and say it's probably as described in the TSB. I got my C6 in January and noticed the noise when backing out of my driveway, or sometimes just after putting it into drive pulling out of a spot.
    Just got new brakes last month and the problem went away.
    May 17 2009
    Idaho
    Quote Originally Posted by ilackav8 View Post
    Probably wouldn't be too hard to replace those rings right? I checked the part number and they are $4 a piece.
    Current:
    2002 1.8t A4 Sedan
    Senior Member Two Rings niedzial1983's Avatar
    Jun 05 2016
    surrey, uk
    I have same issue . Blunt metal noise in full lock when reversing and braking ( only happened since last pads change )
    2006 Audi A6 3.0TDI quattro sline le mans | Daytona Grey Pearl
    Mar 26 2009
    2013 VW Touareg VR6
    Wyoming
    I've had the same issue in 2 C6's. My '06 had it at around 100k and had all of the pads rotors replaced with no change. Also have it in my '09 even after I replaced the pads and rotors, again, I'm around 100k but noticed it around 70. The noise is more like a groan and happens well before full lock at low speeds. Especially annoying around parking lots. I have also found it's much more prevalent in higher temperatures. Basically not an issue at all in the winter, starts coming out around 70 degrees and is worse the warmer it is outside.
    On the '06 I had the dealer take a look and they didn't find anything wrong but did hear the noise. Haven't had it looked at on the '09, guess I figured it's just an inherent problem. This is the first I've heard of the TSB though and it sounds spot on. Might give this a go in the next few weeks and see if it helps.
    May 17 2009
    Idaho
    Quote Originally Posted by kmoney56 View Post
    Yup, mine acts in the exact same fashion. Very noticeable at low speeds in parking lots. Only started to notice it once it got warm. I wonder how hard it is to remove those rings off of the brake pistons?
    Current:
    2002 1.8t A4 Sedan
    Oct 31 2013
    Land Rover LR3, Harley Dyna Fat Bob, Triumph Speed Triple
    Washington DC / NoVa
    I'm digging up an old thread. This same issue has surfaced on my '09. Scraping/grinding/groanish type noise while making slow 90 degree turns.... has anyone figured out what the issue is?
    May 17 2009
    Idaho
    Quote Originally Posted by AFONE View Post
    Basically the consensus I came to is that it's nothing to worry about. There is a TSB that addressed this issue. The problem is the caliper piston seals, I believe they were a tad too thick which doesn't allow the piston to retract all the way. Here is all the info: http://uberlame.com/a6_tsb/Brakes/Br...w%20speeds.pdf
    Current:
    2002 1.8t A4 Sedan
    Oct 31 2013
    Excellent, thanks!
