    Oct 21 2005
    y
    P1338 CPS open or to plus
    1.8t AEB
    What are the symptoms of a bad cps?
    Are running extremely rich and barely has any power one of them?
    Where's the best place to start to diagnose (ie easiest to hardest)?
    What i checked:
    1. Tried a different sensor
    2. Cam gear timing mark is 1/3 to the right of the valve cover
    3. Changed plugs (thinking meth flooded engine)
    4. Disconnected ic piping to throttle (Mafless. To check if piping was flooded with meth, has happened before lol)
    Haven't checked:
    Wiring
    Ecu
    Cam tensioner 16teeth (inside valve cover)
    Compression
    Ecu inj duty and timing request
    1.Was driving in boost and everything was fine (was playing around with the methanol prime and purge)
    2. Slowed down and engine just died
    3. Tried restarting
    4. Coasted to the side of road. Car was still a bit drivable, then engine died
    5. Tried restarting long crank, pedal floored, starts then revs to about 1500rpm and dies
    6. Reduced fuel by around 60-70% to get it started (rough tune, just reduced large parts of the maps to get it somewhere near 14)
    7. Afr was around 13-15afr
    8. Barely had enough power, needed to rev and slip clutch to get moving.
    9. If i let revs drop it would idle very low, but steady, at 600ish and wouldnt respond to gas pedal, need to restart and hold revs to around 1500rpm to get any response.
    10. No out of the ordinary sound, even engine starting/cranking sounded normal.
    Oct 21 2005
    y
    Also will a dead crank sensor cause this? Vagcom can read rpms with the cam sensor unplugged.
    It starts with the 60% fuel reduction from normal and barely any power to move.
    Oct 21 2005
    y
    Checked the socket pins, key on
    1 = ground
    2 = 4.9v
    3 = 5v
    Oct 21 2005
    y
    Checked timing chain. Its 16 links.
    Anyone have any idea what could be causing this?
    Oct 21 2005
    y
    Tried a diff ecu (euro aeb) = starting got blocked by immo but p1338 code still popped out.
    Tried a diff crank sensor, still the same code.
    Pin 2 now shows ~11v (batt is currently slightly below 12v)
    Comp test ~150psi
