Results 1 to 11 of 11
    Active Member One Ring joker4230's Avatar
    Jul 25 2016
    Twin Cities MN
    Diagnose My Audi Please!
    So i bought this Audi a few weeks back and i brought it home and noticed that the oil was black as crap so i thought NBD ill just change the oil. So i changed it out and put a new filter in and when i when to start it up this loud rattling noise started to occur. Ive tried different shops and forums and nothing that i can perfectly pin point. Im thinking timing chain or bad oil pump maybe even both I just want a few opinions on the car so i can narrow this down and get this crap fixed. Let me know what you guys think please !
    Feb 24 2004
    Minneapolis
    You need a stethoscope. But sure sounds like that timing chain is about to fly apart. I can damn near hear it from here in Eden Prairie.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 08 2012
    Dallas, GA
    Holy crap. Stop driving it! If it's loudest back there, you need to get that cam chain cover off and look at it. Sounds like it's stretched so far or the tensioner is so shot that it's rattling against everything in there and you don't want it to jump teeth.
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Cam chain tensioner?
    http://www.audizine.com/forum/showth...ioner-DIY-2-0t
    This drives me nuts that people use these terms interchangeably, the back is the cam chain, the front ins the timing belt. Creates confusion, especially for people ordering parts.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Jul 25 2016
    Twin Cities MN
    Quote Originally Posted by mtroxel View Post
    Thanks for you input. AND HAHA yeah you probably can hear it! shit is so loud so yes i did stop driving it as well hoping to have audi just fix it to get it over with can't spend anymore money on mechanics that don't know what they're doing
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    The rear cam chain tensioner is activated by oil pressure. When I first started my brand new motor, even after priming it as suggested, the rattle lasted a few minutes until enough pressure built up. So it could be that but it should resolve after a few minutes at max.
    So far the only variable you changed is oil and filter.
    Which oil did you use?
    What filter?
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Jul 09 2009
    Cleveland OH Area
    Yeah, its hydraulically adjusted. Good point.
    Jul 25 2016
    Twin Cities MN
    Quote Originally Posted by rongeur View Post
    What filter?
    5w-40 castrol edge syntec
    and a bosch filter at the time then switched to wix
    Jun 04 2011
    Clayton, CA
    The sound sounds just like the rear cam chain is slapping due to a fault in the tensioner. There have been reports of the tensioner wearing through the plastic guide but that is not a common failure. Check for any codes and if you feel comfortable with it, remove the rear cam cover and inspect. It is very tight space back by the firewall but you should be able to inspect the chain and tensioner once off. However, replacing the tensioner is a real PITA as you have the choice between removing the entire cam girdle plate and reseal vs trying to removed the ridiculously torqued cam adjuster bolt. You will need a cam locking tool, and a new gasket for the rear cover at a minimum. If removing the girdle plate, you will need some new green special OEM sealent and new girdle bolts as they are one time use.
    Maybe you can boroscope through the HPFP hole first before removal?
    Build Thread
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    You can get a cheap camera off and app called WISH, it will fit down there, cost like $ 10 but the only problem is it takes a month to get here. Its nice though and has built in LEDs. 3mm or so.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Jul 25 2016
    Twin Cities MN
    Does anyone know of the cost to get this repaired on my audi. I just don't trust myself working on these types of projects on my car
