Uh... One thing after another with this project...
So finally got all things put together, wanted to take it for a quick spin and noticed that as I was backing out the engine would engage and then suddenly slip. Then I put it into first gear and same thing, it would start engaging and then all of a sudden slip. After a couple more tries the engine would not engage at all, the clutch is acting as if it was pressed in.
I'm going a bit crazy on what it could be. I put in a new RS4 clutch with pressure plate, and also resurfaced the existing flywheel. There's consistent pressure on the pedal as I press and depress, makes me think that the slave cylinder is fine.
Frankly I can't imagine how this is even possible. Could it be that flywheel was resurfaced too much?
