Results 1 to 14 of 14
    Established Member Two Rings ekpyr's Avatar
    Jul 16 2007
    Long Beach, CA
    Audi RS7 Stage 2 and Audicare 15k prep?
    I'm nearing my 15k service and my shop suggested I "return to as stock as possible" before going to the dealer.
    Clearly, it's not a simple task to lose the downpipes. In addition, I've also got the Roc Euro intake, custom 3" exhaust piping and KW HAS suspension.
    If you're on Stage 2 with downpipes, how are you handling Audi service?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I would not consider swapping out the downpipes, exhaust, or suspension. I would however definitely flash back to stock as that's the big issue when it comes to being flagged "TD1".
    Your choice on the intake. Most dealer technicians will not bother entering that into the system, and even if they do, it would only matter if you had a failure related to the intake, like foreign object ingestion, which there's almost zero chance of.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Active Member Two Rings Oblivia's Avatar
    May 06 2013
    Expedition, F150, M35X
    Tacoma, Washington
    I would think it might be cheaper to have the 15k servicing done by a private mechanic. I just had my 15k service done at Audi and they didn't do much other than change the oil and rotate the tires.
    How fast is fast?
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Return the software to stock. I didn't on the assurances of a dealer that told me they wouldn't run a spec actual and I still got flagged. Returned to stock for my next scheduled service and that apparently resulted in the TD1 being removed .
    Jul 03 2015
    la
    Quote Originally Posted by ekpyr View Post
    there is only 1 audi dealer that doest care if its tune call call john at 18189321672 but if its just a oil just pay out of pocket
    Jul 26 2016
    South Fla
    Does flash back to stock not show in some kind of event logger?
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Brooklyn View Post
    Wow, so your TD1 flag got removed? I guess thats good to hear.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    May 08 2004
    NoVA
    That's the word from my dealer. Hoping to learn more today, but according to him it was flagged in Nov when I visited another dealer, and when they scanned it yesterday the flag was gone. What I need to confirm is whether it being flagged at all previously is problematic down the road.
    Quote Originally Posted by Djpeaksd View Post
    Jul 16 2007
    Long Beach, CA
    Quote Originally Posted by nickrs7 View Post
    Thanks for the referral!
    Apr 17 2015
    Wi
    change the oil and rotate the tires yourself---that way you don't have to worry about it
    2019 Daytona grey rs3
    2018 navigator black series
    2015 RS7
    2014 f150 raptor
    2013 GTR
    Jul 16 2007
    Long Beach, CA
    Just a FYI on what I did. I ended up going to the dealer whom I've been going to for over 10 years across some 8+ other Audis and VWs I've owned. I've know the SA for that same amount of time. I was completely transparent and told him I needed 15k service and that my Audi was fully modded. I asked if there was anything I should do to make sure I don't get into any trouble. He said he would make sure the tech does not run a spec actual on the car and ignore all the mods. I also had some problem with clicking from the front wheels that I wanted them to look at. They did the 15k service and did a test drive. Acknowledged the sound but refused to dig further citing the mods. I asked what I should do and they suggested I have the shop that installed the springs and sway bars take a look. I asked what I should do if the shop identified a part that was not spring or sway bar related was at fault and they said I have to return it to stock before they can look because Audi warranty will ask if the suspension is stock. Suffice to say, they won't bend over for me but that's OK. I don't blame them for being careful. They didn't flag my car, so I can at least have my Audicare done there.
    Nov 27 2012
    Houston/Texas
    I always flash back before going in and never have mentioned the tune. Only other mod I have is spacers and the VAG-COM drop, neither of those have ever been mentioned.
    2016 S6 | Prestige | Daytona Grey Metallic (APR Stage 1 ECU/TCU, AWE Exhaust, Eurocode Sways and Links)
    Jul 16 2007
    Long Beach, CA
    I didn't flash back. My SA said they would detect it if they did a spec actual. But since they purposely were not doing one, they wouldn't detect it. I had a pretty obvious Roc Euro dual CAI in the engine bay I left in.
    Established Member Two Rings SITH7's Avatar
    Jun 30 2016
    Boca Raton, FL
    Fair to say, wherever you are, make friends with your SA. I've befriended mine and it's nice having an ally.
    2018 Q7 Prestige Brilliant Black
    Full SQ7 Body | S-Line Flat Bottom Steering Wheel | Carbon Fiber Interior Trim | S-Line Perforated Shift Handle | Euro Sweeping Tails | 22" Black S-Line OEM Wheels
    SQ7 Exhaust Conversion & CETE Lowering Module
    2016 S7 Brilliant Black
    Parted out and currently awaiting surrender to next owner with mixed feelings.
