Results 1 to 40 of 68
    Mar 04 2015
    Houston, TX
    Shrieking sound coming from engine bay
    I was idle at a stoplight and heard this nasty shrieking noise. At first I thought it was a broken siren in a nearby lot but after I drove off, the sound followed. The car still builds boost and the noise changes with the RPMs. I thought it might have been a pulley but the more I listen to it, it sounds like it's coming from the turbos.
    Have any of you s6/s7 guys experienced this before? Car has an APR Stg1 and my tuner is out of town or else I'd take it straight to the dealer. I feel like I'm gonna hear something pop soon...
    Apr 14 2016
    2014 Mustang GT500, 2015 BMW R1200 GSA
    Northern NM
    Sounds like you are about to be a candidate for a RS7 turbo upgrade. Sounds like a bearing is bad in a turbo. I wish you luck in that it is something simple.
    2014 Estoril Blue S7
    Nov 02 2008
    A mess.
    Grapevine,TX.
    It does sound like a metal on metal squeal, but the turbo should not do that at idle. With that much friction, it would not spin unless under throttle.
    Established Member Two Rings DirtyVegasTT's Avatar
    Apr 29 2009
    Vegas
    My dealer was telling me about this known problem for 4.0T. It's some sort of a membrane valve within (?) the engine (not a diverter valve) that goes bad and start making this crazy honking / whistling noise. Audi dealer will know what to do with it... but your APR tuned... so let us know how that goes.
    2013 A8L 4.0T
    APR | 22x10.5 Vossen VFS1 | 285/30/22
    Gone - But Not Forgotten
    2007 S6 V10
    APR | Miltek Catback | MSDS Filters | RS6 Grill | LLTek Spoiler | H&R Sport Srpings | 20x9 Hartmann B7 HRS4 | 265/30/20 BFG G-Force
    Mustang Dyno: 342 AWHP, 338 AWTQ - Back then it was pretty good for N/A Audi
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Don't panic. It's not the turbos. There have been a few reports of this on older S6/7. It's somehow related to the PCV (positive crankcase ventilation) valve. Unfortunately it's a bit of an act to get to it, as it's under the turbo output ducts.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Mar 04 2015
    Houston, TX
    Quote Originally Posted by DirtyVegasTT View Post
    Is there any documentation or TSB out there for this? I'm wondering if I can drive on it, although the embarrassment factor is enough for me to just let it sit lol
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    That's an air leak sound. It is loud and I'm glad it's not coming from my engine.
    Mar 04 2015
    Houston, TX
    So it's definitely the PCV valve. Exact same symptoms at this video:
    https://www.youtube.com/watch?v=lZ4KwXaAmtU
    I took the oil cap off and the sound went away! Unfortunately, I dont think its a good idea to drive it with all that pressure built up...
    Thanks everyone for the help
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Yikes! Sounds scary. Glad to hear it's not likely the turbos though. Good luck on getting it fixed!
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Apr 14 2016
    Northern NM
    Glad to hear it isn't a turbo! Good luck with the fix.
    Mar 08 2010
    AudiLand
    It's pcv ... My s6 had the same issue. Was a relatively easy fix.
    Registered User Four Rings PAT@RSW's Avatar
    Jul 02 2008
    BMW M4, SQ5, SL65 AMG
    Green Brook, NJ
    Its 100% a failed PCV Valve. Requires a bit of removal to get to...
    Jun 23 2011
    Toms River, NJ, USA
    Here is a video I put together earlier this year. Same issue, was the PCV covered under warranty.
    https://www.youtube.com/watch?v=bzl8BkIeYRM
    Mar 04 2015
    Houston, TX
    Got the car flashed back to stock and took it in. Dealer replaced the PCV and leaking turbo lines under warranty :). Thanks for the help and easing my mind!
    Registered User Two Rings
    Apr 26 2016
    Houston, TX
    Nice! Gotta love the TD1 avoidance plan!
    May 04 2010
    2013 Audi S6, 2014 Audi Q5 TDI, 2015 GSW TDI 6-spd
    Duluth GA
    Mine just starting doing this today. My first thought was a belt or tensioner but the pitch didn't change with engine RPM. I also thought it could be the turbos since the sound was coming from that general area, but there are no boost issues and no codes. A 30 second search turned up this thread and video and BINGO it's the exact same sound. My car is already flagged TD1 so it'll be interesting to see how this works out. I could argue however that the PCV valvue should not be affected by increased boost? And it seems to be a known issue....
    Robert Cheng
    2014 Q5 TDI, Phantom Black, S-Line, B&O, Nav, Side Assist
    2013 S6, Estoril Blue, B&O, LED, cold weather, comfort seats, rear shade, BBS CH-R 20x9 ET25, Stasis 25.4mm RSB, Alu-Kreuz
    2010 S4, 6-spd, Meteor Gray, Prestige, Sport Diff, Strat shifter, H&R Rear Sway -- SOLD
    2000 S4, 6-spd, AWE stg3, lots of other stuff -- SOLD
    Junior Member Two Rings
    Aug 08 2016
    ohio
    Wow, I have the same problem. Mine is getting fixed today.
    2013 S6 estoril blue
    Previous: 07 A8L
    01 allroad
    May 04 2010
    Duluth GA
    Audi denied my repair due to TD1 flag (which I knew I had). The dealer I went to however said they would do a one-time good faith repair and cover the parts if I paid the 10 hours labor. This issue is covered by TSB 2040644/5. The faulty part was an oil separator. and not PCV valve. Here is the complete parts list from the work order:
    079 103 542 D SEPARATOR
    079 145 818 SEAL
    079 129 717 K GASKET
    079 129 717 J GASKET
    079 129 417 B SEAL
    079 129 417 B SEAL
    N 904 898 01 CLIP
    N 904 898 01 CLIP
    G 013 ABJ 1G COOLANT ADD
    N 904 095 01 CLIP
    Robert Cheng
    Mar 04 2015
    Houston, TX
    Quote Originally Posted by maxhawk View Post
    079 145 818 SEAL
    079 129 417 B SEAL
    079 129 417 B SEAL
    N 904 898 01 CLIP
    N 904 898 01 CLIP
    N 904 095 01 CLIP
    Don't do it. I got around my existing TD1. Long story short, I got the ECU/TCU update and it removed my td1 from Audis database. I brought the car back for this fix and no more tD1! I'll post later tonight with the details (posting this while commuting).
    May 12 2011
    2016 RS7 Stage 1 APR; 2012 Porsche 911S Cabriolet Black Edition; 2015 Cayenne Diesel (DD)
    Rockville, Maryland
    Quote Originally Posted by tph4m86 View Post
    I just paid $2700.00 to have this issue fixed. I'm tuned but not TD1. I'm at 79k miles though so out of warranty. If there's a TSB, does that mean it should have been fixed at no cost?
    Mar 26 2010
    US
    Quote Originally Posted by Phknlwyr View Post
    When under Audi warranty, it might be covered.
    The TSB offers instructions on how to fix.
    2019 RS5 Sportback
    Veteran Member Three Rings Packy's Avatar
    Dec 12 2011
    2009 Audi A4, 66 Corvair Corsa Turbo (future project car).
    Arizona
    Mine just started doing this. 2 months left under warranty. no tune. I'm also thinking this may be an emission control device, which means 100K mile warranty per federal law.
    Does the TSB say if any upgrades were done so It doesn't happen again?
    2013 S6, 2009 A4,
    Mar 09 2017
    Bay Village OH
    I had the same thing happen right after warranty expired. My local VW/AUDI/PORSCHE tuner did the job for half the dealer. It's all in the labor cost since the part sits in the V under the turbos.
    Established Member Two Rings Noizy Child's Avatar
    Jan 23 2017
    Pittsburgh, Pa
    Getting this done Monday... Fun fun fun
    Sent from my Nexus 6P using Audizine mobile app
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    I'm getting mine done on 3 Jul in conjunction with the 21F2 service campaign. Damn thing started whistling a couple of days ago.
    Drew
    Jan 23 2017
    Pittsburgh, Pa
    Mine started whistling last night otw home from work. ANNOYING haha.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Mine started Thursday evening - MAN is that a loud whistle it makes!!
    I hadn't previously noticed this thread, so had no idea what it was, but when I called the dealer to schedule an appointment, they identified it right away. I'll have it back Monday, covered under the CPO warranty, and I'm in a loaner B9 A4 until then.
    While it's there, also having them do the 65K mile service, and they're performing the turbo coolant line and ECU updates (per the TSB/recall).
    Oh, and BTW - B9 A4 is a slick, slick ride. Unbelievably refined in every way, and not slow.
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Established Member Two Rings barrygold's Avatar
    Jul 24 2017
    Midwest
    Got mine done yesterday at the dealer. Warranty flagged for APR tune, I didn't try to hide the flash. S8 4.0.
    Paid $1500. Ouch. Independent shop wanted $1300 but dealer gave me brand new A8 for a loaner for free.
    I didn't have whistling yet just a code and oil residue around the oil filter cap.
    13' S8 APR Stage 1
    Established Member Two Rings ehofmann's Avatar
    Dec 22 2014
    Colorado
    Mine gave out 2 weeks after buying the car. Sounds like a train running over cats. Luckily I have an aftermarket warranty that covered it.
    Dec 22 2014
    Colorado
    Just wanted to update but my car has started making the sound of death again, although not nearly as bad as before. Starting to eat oil and there seems to be excessive vacuum pressure when I take off the oil cap. I think my replacement part was defective goddamnit. Taking it in today to get checked out. Anyone have an updated pcv/oil sep fail?
    Mar 21 2014
    buffalo
    Quote Originally Posted by ehofmann View Post
    What warranty do you have. I have the top line GWC and they claim they won't cover it
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Looks like the newest version is “E”, anyone with a ‘16 or ‘17 that has had to replaced this?
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Established Member Two Rings RedheadNV's Avatar
    Apr 05 2017
    Reno, Nv
    Quote Originally Posted by nefkntym View Post
    I just finished replacing mine tonight and on the box was “E”, but in the box was “D”. I’m hoping that I don’t have to do it again.
    2013 S6 Quartz gray metallic
    Dec 05 2016
    Westminster, CO
    Old one was a 'B' for me, replaced with E. According to ECS, there have been 3 iterations of this box: B, D, and E.
    Mar 17 2017
    Redondo Beach, CA
    For the guys that had a failed PCV/oil separator, did you have any codes stored, CEL or other signs it was failing BEFORE the squealing/whistling noise and high vacuum on the oil cap? And when the noise started, was it gradual or loud all of a sudden?
    In WhiteWhiteS7's very informative how to replace Oil Separator thread, he listed P050700 as one of the stored codes in the TSB troubleshooting http://www.audizine.com/forum/showth...arator-R-amp-R
    I'm wondering if the 2 codes I have are an indication my PCV/oil separator is going bad, codes come back intermittently after being cleared:
    P050700: Idle Control System RPM Higher than Expected
    P045600: EVAP Emission Control System Very small leak
    Would rather be proactive to have it replaced before the horrible noise starts if I can (have 3rd party extended warranty).
    2013 Phantom Black S7 | Bang & Olufsen | Driver Assistance | Night Vision | HUD | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
    Sep 28 2009
    suburb
    My noise started out of the blue and got super loud in 2 days. I had no codes until it was really loud
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Apr 05 2017
    Reno, Nv
    Mine started to make the lovey noise instantly. I didn’t have any codes until I pulled the oil cap to make sure the noise went away.
    Jul 24 2017
    Midwest
    Quote Originally Posted by SleekS7 View Post
    I never had squealing but I had a CEL of leak in intake.
    Indy shop informed me if you don't remedy the PVC valve issue in a timely manner you risk blowing your rear main seal due to the increase in crank case pressure
    Sent from my Pixel XL using Tapatalk
    13' S8 APR Stage 1
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    my god what else could I possibly need to be fixed now this lol. While attempting to find my coolant leak smell I noticed this sound, sounds like its coming more so from the drivers' size but hard to tell. I hate my local dealer don't trust them doing fixes, has anyone attempted to fix themself?
    Jan 02 2018
    Deleted
    Hey guys, was wondering if the noise I just noticed on my brand new S6 has something to do with the turbos, and if normal or not. When coming to a stop, hear a winding down noise that sounds like a failing HVAC fan, but it's obviously not the fan, since it winds down. Thought it was the A/C compressor, but I don't think it is. Is it the turbos? Sounds not unlike a leaf stuck on the HVAC fan. It's not loud, since I haven't heard it before due to having the stereo on. I don't really mind if it's normal, but would like to know if it's normal, or something not right in the engine compartment. Even my wife asked me what's that? Since I didn't have the stereo on. Thanks gang.
