    Apr 15 2014
    Ottawa/Gatineau Canada
    Do "painted lowers" swap off a b6 easy?
    I have a hole in one of mine and was wondering if this plastic piece, the same one painted on late model B6 ("painted lowers") swaps off a parts car easy?
    Bad pic, but this piece below the doors...
    Thanks
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Yep. Pretty easy. Pull up the rub strip and there are a handful of bolts uner the strip. A few underneath along the bottom and a few at each end. Once you get started they are all pretty obvious.
    Apr 15 2014
    Cool beans.
    What is a "rub strip"?
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Open your doors and there's a plastic trim you gotta remove. Ton of torx screws all along the thing. A few below the car and a few in the wheel wells in the fender liner.
    If you're lowered, the rears will be a bitch so you might have to pull the wheels off.
    Audi Club Bay Area
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Any of you guy's rattle canned the lowers? I found a place that can match my paint code. I may go this route after taking it to a body shop and was quoted 1300 to just paint if I removed everything and separated the front and rear bumper lowers.
