Results 1 to 16 of 16
    Veteran Member Four Rings MerlinS3's Avatar
    Aug 04 2010
    2023 SQ7, 2021 Exclusive SQ5, 2022 Exclusive RS6
    Frisco, Tx
    E-Code headlights...
    So I came across an opportunity to swap my OEM LED headlights for LED E-codes with $250.00 on top of the swap...
    Is this a good deal?
    I know E-codes are about 2,500 depending where they are bought, not sure what the OEM LED's are worth though,
    little help before I pull the trigger!
    thanks guys
    [CENTER]CURRENT | RS6 Avant | Audi Exclusive | Uni Stage 2
    CURRENT | 2021 SQ5 Prestige | Exclusive Paint | Sport Exhaust | Black Optic | Dynamic Steering | Sport Package | BC Forged
    CURRENT | 2023 SQ7 | Stealth PPF | Lowered |
    Aug 06 2012
    san diego
    great deal- just kind of curious why they would be letting them go for that price. is anything wrong with them?
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    terrible deal. give me the guys number so i can set him straight.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Apr 11 2012
    great deal if there's nothing wrong with them. why does that person want oem us spec ones? selling the car?
    Aug 04 2010
    Frisco, Tx
    Quote Originally Posted by markn1689 View Post
    Quote Originally Posted by diztek View Post
    Quote Originally Posted by will13k7 View Post
    His lease is up in 2 weeks and I actually reached out to him seeing if he would swap since he has to turn the car in anyway, might as well give someone else use of the E codes lol and he said sure!
    I talked him down from 500 to 250 on top of the swap.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Quote Originally Posted by VeeDubb View Post
    Yea that's a fantastic deal as long as you're OK giving up your NA spec lights. I'd be all over that if I didn't already have ecodes and the opportunity presented itself. The car looks infinitely better with ecodes. You'll see what I'm talking about when you do the swap. :-)
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Aug 04 2010
    Frisco, Tx
    Quote Originally Posted by phillyquattro View Post
    Yeah I'm totally cool giving up my NA ones for this deal lol.
    Is it easy to swap out the headlights or is it a bitch?
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Once you remove the bumper cover they are pretty easy to remove.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Aug 04 2010
    Frisco, Tx
    Awesome, was hoping it was as simple as removing the bumper and they come right out
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    You can remove the headlights without removing the bumper. These things are so pretty. If anyone would like a quote, pm me :)
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Would like to know that as well, might sway me to bit the bullet.
    2016 Monsoon S3
    My slow build link - Onequick4door
    Apr 18 2016
    Tucson, AZ
    Quote Originally Posted by onequick4door View Post
    Ditto
    Mar 01 2016
    Atlanta
    Quote Originally Posted by reyoasian View Post
    How? I thought the S3 had a screw at the bottom which required removing the front bumper cover to get to?
    There is indeed a screw on the underside. Some friends and I just put mine in last week. There is also a little ring/hole that you'd have to probably break near the front quarter panel that one of the tabs under the headlight slides into but I don't really recall since I had my bumper off...
    The picture also appears to be B8.5 S4/A4 e-codes.
    Aug 06 2012
    san diego
    the bumper needs to come off. without a doubt.
    not a big deal though. i did this mod without jacking the car up. took me an hour or two
    Aug 04 2010
    Frisco, Tx
    That's what I thought, when I did my RS grill it appeared that's the only way to get the headlights out.
    Just a torx set and should be all dandy
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Quote Originally Posted by pabs View Post
    Correct... when multi-tabbing Audizine goes south.. you wind up in the S3 forum instead of the B8 forum. 8V does indeed require bumper removal... annoying right? And yes those are B8 E-codes pictured, but we can get the 8V LED E-codes fully loaded too. PM me if you guys want a smoking deal. drumming up a Group buy right now if there is interest in one.
    Greg
