Results 1 to 10 of 10
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Intake piping and flow
    I'd like to start a discussion about intakes. I don't care about the filter in this discussion. It's not meant to be an argument about which overly priced filter is the best.
    I have been toying with an idea for some time about doing a custom intake, which in my research has not been done before. The only question that I really have is intake piping size. I was hoping that I could have somewhere in the realm of 3 inch intake piping from the filter to the TB. However I don't understand the flow properties when piping needs to neck down. To me if you manage to have 3 inch intake piping all the way to the TB but the TB then necks down to 2 inches, then that 3 inch piping is a waste and you might as well just used 2 inch piping the whole way.
    It seems to me that if you wanted to really make use of the piping you would need to start at the intake manifold and change everything to be the same size piping as the inner diameter of the intake manifold, as any larger piping would be restricted to the size of the intake manifold.
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    :facepalm:
    Dude, there are so many intake threads..and you want to start another? It's a PROVEN FACT that aftermarket intakes on the 2.0T b7 do little if anything to improve performance. Only thing they do is add a little sound.
    Nov 07 2015
    Pennsylvania
    The only intake threads I've ever found were along the lines of is the apr or other cone filter intakes with it. And little discussion on the actual intake piping size and opening up the entire track, not just popping on a cone filter. Perhaps you can point me to a thread that talks about the piping size?
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Throttle body? You should make the pipe as wide as the turbo inlet.
    Any neck down becomes your bottle neck.
    People have done custom tubing for a while. You suck at searching
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Senior Member Three Rings pule333's Avatar
    Jan 14 2013
    Mi4cxl
    london/UK
    Here you go. Your search is over.
    Filter-3"-2.75"-2.25"-turbo- 2.25"-2.5"-intercooler-2.5"-2.75"-Q5 throttle body.
    Vorsprung durch Technik
    Nov 07 2015
    Pennsylvania
    Thanks pule that's essentially what I was looking to do.. I guess my searching on this was weak sauce cause all I could ever find about it was arguments about air filters and nothing about the tubing.
    Jan 14 2013
    Mi4cxl
    london/UK
    Quote Originally Posted by Rulty View Post
    Essentially you are limited by the turbo inlet-outlet. And throttle body. Go for Q5, it's 2.83" I believe. All other tubing is 2.5". Use welding where possible don't rely on silicone couplers.
    2.5" is more than sufficient for ko3,ko4 turbos.
    But this will produce a lot of sound. It will be loud :) if you don't want it loud, just put a panel filter like K&N or pipercross and stick with OEM air box. It has Ben proven that AFTERMARKET kits like APR, etc don't do shit! If it's the sound you after what I posted above is the best option. Might even give you a 0.5hp ;)
    Enjoy!
    Mar 18 2014
    Dunedin Florida
    and there you have it.
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    If you run a 3in intake your man reading will be off. the stock may size is 2.75. you could use the atp turbo mad pipe that fits 3in pipes but goes down to 2.75 right where the maf reads, not sure how good that works though.
    Nov 07 2015
    Pennsylvania
    Wasn't exactly looking for sound, could care less about it to be honest. I thought I was on to something as I never seen it done before but I guess these intakes are just about as good as they get.
