Results 1 to 9 of 9
    Established Member Two Rings B5Riches's Avatar
    Dec 15 2015
    Bayside, NY NYC
    Installing remote start in my manual 1.8t
    Hello all I am attempting to install a compustar cs650 remote start alarm in my b5 1.8t manual. Has anyone tried this as I saw online via compustar site 2001 doesn't have an immobilizer? Therefore I don't need the bypass? Not sure if without an immobilizer that I don't need an bypass still. I know German cars are illegal to install remote starts in Germany.
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    euro B5's had immo, american B5's did not, so no immo to bypass for you.
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Dec 15 2015
    Bayside, NY NYC
    Quote Originally Posted by down_n_dapper View Post
    Thank you so the install is pretty much straight forward?
    Dec 15 2015
    Bayside, NY NYC
    Any idea on how to bypass my clutch?
    Jan 18 2015
    2013 Audi Allroad
    Pittsburgh, PA
    In my truck I used one of the auxiliary pins (meant for heated seats/etc.) to ground the sensor on the clutch pedal. This way it still requires the clutch to be depressed when started normally, but it let's the remote start work when the shut down procedure has been followed to ensure its in nuetral.
    Dec 15 2015
    Bayside, NY NYC
    Quote Originally Posted by REBinc View Post
    Alright tried to ground the clutch and ending up ripping the pos and neg wires loose from its clip holder. Now car cranks won't turn over much like fuel pump or hall sensor issues...thoughts?
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Why are you doing this?
    Dec 15 2015
    Bayside, NY NYC
    Quote Originally Posted by adam044 View Post
    At first I didn't and just unplug the sensor and ran fine but then few ppl suggested it and now this sigh, but the blue wire is also cut from under the steering wheel. I know I screwed up but it was for something that could of got me an job now NOTHJNG but a dead car. What's the effect you think?
    Dec 15 2015
    Bayside, NY NYC
    Any idea why my car would crank but no start? Ignition switch toast or starter burned out?
