Results 1 to 6 of 6
    May 27 2016
    Atlanta
    OEM exhaust valves after installing AWE
    For you guys that have installed an AWE or similar system, what did you do with the electronic exhaust valves? Mine are currently 'tucked' up in the heatshield area above. But I'm wondering how much rattle noise or possible damage that might cause - to them, or anything else.
    Sent from my SM-T813 using Tapatalk
    Registered User Four Rings
    Jun 25 2016
    DMV
    I was wondering the same thing actually. bump
    i figure worst case, they insulation melts and then i splice a new connector on there? haha.
    Senior Member Three Rings Drichardson72's Avatar
    Apr 11 2015
    Vancouver, Canada
    Don't they cut them and put a little relay or diode on them to prevent error codes?
    Oct 26 2015
    Norman/OK
    Ive had the valve controllers unplugged on ours for almost 2 months now, no codes what so ever.
    Jun 25 2016
    DMV
    they offer caps to protect them, and even a little module with a relay to plug it into. i just electrical taped them up, its not gonna last though. lol
    - - - Updated - - -
    i believe there is a silent code for not having the exhaust switches plugged in. u won't see it unless u run a full scan in vcds. don't quote me though! just what i heard
    May 27 2016
    Atlanta
    Yeah, they came with some plastic tips. Didn't see much point. Or you can buy some loop relays (I guess that's the right term) for an extra $50 that should prevent codes. But, still...where the heck do you put the damned things?
    Sent from my Nexus 6 using Tapatalk
