After a timing belt procedure (low pressure lines disconnected from the cooler) I noticed my power steering was very difficult to turn. I figured I had air in the system. I tried adding fluid, bleeding the air out (turning wheel lock to lock with wheels in the air) and all the other things suggested in the forums. There are no longer any air bubbles appearing in the reservoir. I have replaced the pump, small hose coming from the pump and both lines connected to the cooler, but nothing has helped. The new low pressure hose came without restrictors so I swapped the old ones over. The PS rack has no visible leaks and feels smooth enough with the engine off and the wheels in the air. I don't detect any notchiness or anything. But the steering still feels ridiculously heavy. Feels like servotronic is out, but it didn't come with servotronic. Please, any ideas?
