I've searched Ross-Tech and AZ and I'm still unsure on diagnosing my problem.
Recently maintenanced the rear brakes w/ new rotors, pads, lines, and replaced the piston seals (fronts are running 18z BBK). Went to bleed the brakes per Bentley by pressure bleeding w/ the brake pedal held in a depressed position. Pumped my bleeder up to 2 bar (29psi) and started the bleed process from passenger front, driver front, passenger rear, and driver's rear. Got a good amount of air out of all four corners. The car was on jack stands in the rear and the front was sitting on the ground. Got a nice firm pedal after the bleed. After putting the wheels back on and starting the car the pedal drops to the floor. There was no resistance.
Day two, decided to go buy two more jack stands thinking the angle of propping the back of the car may have caused some air to get trapped in the hydraulics. Jack up the front. Re-bled per Bentley except this time around I decided to manually press the brake pedal to bleed w/ the pressure bleeder hooked up to 2 bar again. This time around hook up VCDS to perform the abs bleed function. Couldn't get the ABS to read and quite for the day.
Day three:
With VCDS I logged in w/ code: 07497 (someone correct me if I'm wrong in my login)
per Ross-Tech:
Login
Note #1: After Login has been carried out you need to recode the control module.
Note #2: Special Login 07499 is used for 6-Cylinder Diesel Engine with 1LG Brakes and Multitronic.
Note #3: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
0?xxx: Chassis
6 = Audi A6 Light Armored
7 = Audi A6
0x?xx: Brakes
1 = 2FNR 42 AL 18" (PR-1LJ/1LP)
2 = 2FNR 42 AL 17" (PR-1LL)
3 = FN3 16" (PR-1LF/1LT)
4 = HP2 16" (PR-1LX)
4 = FNR 16" (PR-1LA/1LG)
5 = FN3 15" (PR-1LB/1LE)
6 = C54 (PR-1LZ)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8 Cyl. Gasoline
0xxx?: Transmission
5 = Manual Transmission
7 = Automatic Transmission (01L/01N/01V)
9 = Continuously Variable Transmission (CVT) / Multitronic (01J)
After login I went to coding and entered 06397
again per Ross-Tech
Coding
Note #1: Coding is accepted after a specific login has been carried out.
Note #2: After successful coding the steering angle sensor basic setting needs to be carried out.
Note #3: Special Coding 06399 is used for 6-Cylinder Diesel Engine with 1LG Brakes and Multitronic.
Note #4: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
Note #5: In some cases, you will need to enter a non-zero WorkShop Code, such as 12345.
0?xxx: Chassis
6 = Audi A6
7 = Audi A6 Light Armored
0x?xx: Brakes
1 = C54 (PR-1LZ)
2 = FN3 15" (PR-1LB/1LE)
3 = HP2 16" (PR-1LX)
3 = FNR 16" (PR-1LA/1LG)
4 = FN3 16" (PR-1LF/1LT)
5 = 2FNR 42 AL 17" (PR-1LL)
6 = 2FNR 42 AL 18" (PR-1LJ/1LP)
0xx?x: Engine
5 = 4/6 Cyl. Diesel
0xxx?: Transmission
Then went to Login and entered 40168 to get to "basic settings"
Under basic settings got the G85 steering wheel angle sensor. Got that corrected no problem. When trying to select ABS Bleed I get a communication error. VCDS will not read or communicate to the ABS Module however it will get error 01486 "system function test activated".
I ran through the system function test procedure to pump the brake pedal to build pressure, ran the car up to 9mph and turned the wheel steady until the ABS light went off.
So my problem is I get a firm pedal if the car is off. I can pump the brake pedal and the pedal will get firm. When the car is on the pedal goes dead (soft) and drops to the floor. I test drove the car despite the weak pedal and noticed if I pump on the brakes I have super solid pedal feel however if I try to press in one stroke the pedal falls to the ground and brakes get applied very slowly (softly) and does not bite. The engine control module via VCDS shows the fault code of "18057" which Ross Tech just describes as:
18057/P1649/005705 - Powertrain Data Bus: Missing Message from ABS Controller
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fault Code(s) stored in Brake Electronics (J104)
Communication Error with Brake Electronics (J104)
Possible Solutions
Check Brake Electronics (J104) for Fault Codes
Check Communication with Brake Electronics (J104)
See Measuring Value Blocks (MVB)
So do I have a faulty ABS Solenoid/Module or is there air my brake lines that's causing the soft pedal? Any way to pull codes off the ABS module itself?
