Results 1 to 12 of 12
    Apr 07 2015
    Los Angeles CA
    GIAC Stage 2 no Cel no Boost, Help!!!
    Here is the Update:
    Replaced the Breather Assembly with 034 Motorsports kit
    Replaced the whole Emissions system with all new components from ECS replaced the DV and the crank shaft sensor
    And now the bad:
    I can hear the Turbo start to Spool at around 2700 RPM and before it would start to pull hard at 3000 RPMs and now there is nothing!!!!
    Please Help!!! Do I have a leack in the turbo Line??!! I am out of Ideas at this point. And there is no CEL or check engine light on.
    Any advice?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    2019 SQ5 Prestige
    Apr 07 2015
    Los Angeles CA
    That was my next step. But I replaced all the components with this
    https://www.ecstuning.com/ES2219685/ & https://www.ecstuning.com/ES2864539/
    What else is there left to Leak? I thought it would be the N75 or the Waistgate
    Apr 01 2007
    houston texas
    Quote Originally Posted by Junglenrg View Post
    A tear on the TIP or any boost plumbing, fuel injector cups, a loose hose clamp, could be many things. Doing the test should make it easier to find.
    2019 SQ5 Prestige
    Apr 07 2015
    Los Angeles CA
    will do it this weekend
    Thank so Much!!!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Definately sounds like a boost leak. I suspect the problem may be with the DV. Check the hoses from the intake manifold to the N249 and from there to the DV. Make sure that there are no cracks or splits in the hoses.
    Apr 01 2007
    houston texas
    Might be a good idea to test the the DV as well 'while youre in there'.
    2019 SQ5 Prestige
    Apr 07 2015
    Los Angeles CA
    I replaced the DV when I replaced all the hoses. I put in 710N.
    When I drive I can hear an extra noise come from the Turbo Housing Area.
    It really sounds like an air leak. I am going to do a test this weekend. At this point it could only be one part IMO.
    Ill let you guys know what I discover, thank you for all your help.
    Dec 25 2004
    Earth
    This car is notorious for boost leaks! You find and fix one, another will pop up!
    I fixed several, and it turned out my oil cap was leaking too!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Apr 07 2015
    Los Angeles CA
    So did the boost test, no leaks... thank God.
    It ended up being the cylinder on the gas pedal... FML
    And now I have Faulty Steering Angle Sensor Error
    Apr 01 2007
    houston texas
    You may need to re-calibrate the sensor with VagCom if a simple drive cycle doesnt clear it.
    2019 SQ5 Prestige
    Apr 07 2015
    Los Angeles CA
    Yea I am waiting to get the Angle Sensor. I am in no rush to get it. since its not effecting the drive.
    I feel like I need to stop updating this thread every time something is wrong with my car which is once a month.
