Results 1 to 3 of 3
    Dec 16 2014
    Irvine, CA
    2002 Tiptronic Allroad Engine into 2000 S4
    I am installing a 2002 APB engine from an Allroad into a 2000 S4 6 speed. Does anyone know if I have to swap intake manifold and spider hose assemblies from the older car? Can I make it work with the 2002 parts? I will be using the engine harness from the S4. Any other parts that need to be swapped over? I know I need to remove the SAI pump and block it off. Anything else?
    Aug 06 2008
    Canadia
    I think the turbo is angled down and is not compatible with s4 downpipes.
    the B5 S4 is like the mafia... there is only one way out!
    Dec 16 2014
    Irvine, CA
    It has early style turbos, so no problem there.
