Results 1 to 7 of 7
    Senior Member Two Rings b7cruiser's Avatar
    Jan 16 2007
    B7 2.0T
    So Cal
    2.0T Cam Bridge Failure
    Has anyone seed this failure. Apparently, this is does not have a part number. To replace, you have to buy a new head... ($6300 with labor)
    A4 2.0T Avant Q 6M
    Phantom Black Pearl with Ebony Interior
    Nav - Convenience - Titanium - Bluetooth - S-Line
    Mar 24 2013
    Oakdale, CT
    Never seen that before. You could probably get that welded. I'd guess something was overtorqued.
    -Adam
    Dec 02 2014
    idaho
    So cal? I know of an excellent welder in Sacramento.... I will see if I can dig up his number, he welded a trans case bell housing that was aluminium for me. He's definitely very talented... Of course it may be a drive for you
    Jan 16 2007
    B7 2.0T
    So Cal
    Looks like it may have been overtightened. Can't see how it would ever stress and break?
    A4 2.0T Avant Q 6M
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    I've seen this happen twice one car broke a valve and one snapped a cam. If the top part is broken there's no way the bottom isn't messed up. You also don't want to put one from another head on as it's probably not going to match up right. Best bet is finding a new head.
    Jan 16 2007
    B7 2.0T
    So Cal
    Nothing really shows the reason for the damage.
    A4 2.0T Avant Q 6M
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Bad cast right at the threads (or next to it)? That's what it looks like just from a general look at it
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
