Originally Posted by
van462
White smoke is what others with injector issues have seen. There is no good way to test. Injectors have been another problem area and Audi did extend the warranty on them. I do not remember the exact number a search n here will likely bring up some decent threads. About the only troubleshooting you can do is pull the plugs and see which one looks wet and fouled and likely that is your cylinder. The fuel rail runs at pressures exceeding 1200 psi so a fuel pressure tester looking for leak down doesn't work. A VCDS cable or carista can read the sensors reading and you can see it bleed down on engine shutoff. Also looking for fuel trims where the ECU senses the rich condition and is trying to go lean but can't correct the condition cia the O2 sensor reading. The fix is replace the injector, cleaner likely won't help. A new injector will also need a new seal and there is an installation tool for the seal. Some have put it on without the tool.
Look over this DIY for cleaning the intake valves, not a bad idea while you are there.
http://www.audizine.com/forum/showth...?highlight=diy
Thanks. So tomorrow I'll pull the engine cover and coil packs out again. I'll check cyl 1 and 3 plugs first since those are the two cylinders identified in the CEL codes, i'll then compare those to cyl2 and 4 for comparison. Audi replaced the plugs maybe 9k miles ago....not that it matters. If none are wet or appear fouled out...then who knows.
Side note -I called the service writer at my local dealership. They consider themselves "tune friendly" and offered to send a tow truck since I'm under the Certified Pre Owned Warranty. I then explained that the car just doesn't seem driveable and that I'd be concerned they would identify the car is tuned as part of their diagnostic procedures and then Audi would stop all work and I'd be up shit's creek...and to add to then have to get the car out of there still in pretty bad shape..she has the CEL codes and is going to check with the shop foreman to see if they have to use the specific diagnostic tool that would identify the tune and flag the car, if not the tow truck will come get it and its their issue to fix..if so, then I have to figure out how to remove the tune or continue trying to identify and fix the issue myself :(
