So last year around august i purchased Depo (helix) RS4 style headlights.
Here's the link https://www.moddedeuros.com/products...-fits-oem-hids
So at some point over the winter the passengers side headlight started to crap out on me. blinker worked, city light worked, high beam worked. the D1S bulb was not coming on. sometimes if i hit the housing it will come on, or if i went over a pothole (god forbid) it would sometimes come back on. then it got the point were it wouldn't turn on at all.
So some goods news, i picked up another S4 this past weekend and started swapping over all my aftermarket and newer parts to the new S4 along with my headlights.
So since the low beam wasn't coming on i figured it was the ballast or the bulb itself so i swapped both out with the ones i knew worked out of my new S4 and the low beam STILL DOES NOT COME ON. WTF..... so I'm guessing its a wiring issue with Depo fixture.
Has anyone run into this or similar issues with OEM or aftermarket headlights? tonight i'll probably use a electrical tester to make sure all wires are OK then go from there.
TIA
