Results 1 to 10 of 10
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Help! Coolant instantly empty
    I got a low coolant warning. The coolant was totaly empty. I refilled and when I start the car the coolant drains immediately. I see no leaks.
    Any suggestions, what can make the coolant drain so fast? hope its not the head/gasket.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Is the car smoking white?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Aug 09 2012
    Bay Area
    Quote Originally Posted by Velox View Post
    Its also possible the system was completely empty hence why once you filled it up and started it it went empty again due to air pockets. Check out where that coolant is going tho. That low means its leaking or being consumed.
    Mar 30 2016
    S4
    Oranjestd
    The car is not smoking white, i have put in 6 litres of coolant. I havent taken of the plastic belly pan, will do tomorrow I really hope I find an obvious leak. but if it's losing this much coolant through a leak surely I would have seen it even with the belly pan in place right?
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    have you done any sort of service to the coolant system recently? if you put 6 liters of coolant in and lost it that quickly you would notice it all over the ground even with the belly pans on. thats a lot of fluid. maybe a Aux radiator bit the dust and it leaking or while you drive it forces it out through a small crack or hole. either way get under the car asap and look around and report back.
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Mar 30 2016
    S4
    Oranjestd
    Thanks for the response guys, I removed the belly pan, which had a big rip in it. It looks like I hit something, I remember hearing I light bang while driving before I got the coolant warning but dint feel likeanything major.
    It is indeed the aux radiator (passengerside) that is the culprit, the bracket that is holding the radiator is bent slightly downward and the coolant is leaking from 2 plastic plug things on the underside of the radiator (no idea why I didnt notice anything yesterday because it's leaking hard).
    Are these plugs part of the radiator and is replacement the only option of is there an easier fix?
    Nov 16 2013
    Lower NH
    glade you found the problem, Aux rad is relatively easy to replace. i usually remove the bumper to get at it. while you're in there replace your snub mount and upgrade to the JHM auto tensioner and maybe the 6 rib pulley if your up for it!! BTW check Genuine Audi Parts for some good pricing
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Mar 30 2016
    S4
    Oranjestd
    Ok thanks for your help, I already have the bumper of. Will replace rad and upgrade mentioned parts
    Aug 09 2012
    Bay Area
    With the bumper off theres tons of stuff you can do. Good time to do a lot of stuff or all of it.
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    I replaced my Aux rad with an A4 unit and think it was quite a bit cheaper. Bracket might need adjusting.
    Sent from my SM-G920F using Tapatalk
