Results 1 to 4 of 4
    Jul 26 2016
    Orchard Park, NY
    Air spring troubleshooting
    Hi guys - first post here (been a long time member on the 'other' forum. New to the allroad, not new to Audis and am having some issues with my left front air spring (passenger side).
    The air spring would leak overnight (especially during cold weather). The bag was replaced by a shop with allroad knowledge with a brand new aftermarket bag (not Arnott) but continues to do the same thing. Looking for some common troubleshooting tips here. Anything to help me narrow down the culprit here? The shop is a good 45 min away so I'd prefer to do the repair myself if possible.
    Tom
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Time to get out the soapy water - check the fitting to the bag, and follow the line back to the junction block and fitting at the compressor. Should be the green air line. You could pull the wheel liner and check the line going into the fender as well, maybe it got nicked or something.
    If all is good there, then I'd check the bag, even though it's new. Then look into the sensors, or the levelers as a possible issue.
    Just an FYI, passengers side is the RIGHT, driver is the LEFT. Perspective is from the drivers seat.
    Good place to start.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    or the easy first step is jack up that corner (put it in 'jack mode' first) and spray the bag and fitting with anything that makes bubbles
    chances are its either at the fitting or one of the two places where the bladder is crimped to the housing
    the air line from the bag to the valve block rarely gives problems unless it was wrecked or something else catastrophic happened
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Jul 26 2016
    Orchard Park, NY
    Thanks for the tips guys - I'll give this a shot.
