Results 1 to 4 of 4
    Oct 21 2005
    y
    Coolant pipe difference? (at mt)
    Other than the part that connects to the oil cooler (different angle) is there any difference between an aeb mt and an apu (euro atw?) auto coolant pipe?
    I replaced my mt coolant pipe with one that came from an auto. Problem is the pipe angles towards the driver side making it impossible to bolt the bracket to the intake.
    Not sure if the pipe is bent or incompatible.
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    There are 3 different pipes. The split happens in the 98 model year. Anything prior to a certain vin in 98 have a specific auto or manual coolant pipe. After 98 they are the same for manual and auto
    Oct 21 2005
    y
    Quote Originally Posted by RagtagXMASTER View Post
    Thanks for the info. Every other post said they b5 pipes were all the same.
    Is the intake manifold also different (external mounting points only, dbc vs dbw)? The coolant flange looks exactly the same, the head where the flange is also looks the same.
    Mainly interested on how the pipe mounts up to the manifold.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Am not sure on the manifolds. I think that the manifold mounting points may also be different. I had all different coolant pipes to know that but i never looked at the manifold.
