Results 1 to 6 of 6
    Active Member Two Rings XtremeXiong's Avatar
    Feb 18 2016
    Hampton Roads/VA
    Audi B8 MAF Pin Help
    Hello all,
    I was wondering if anyone knew where to order pins for the female connector connecting the MAF sensor? I tried calling Audi but they would only sell the whole harness. Below is the listed MFG Part and ECS Part number of the female connector housing. Any and all help is appreciated.
    Mfg Part #
    4F0973705
    ECS Part #
    ES#393640
    Audi B8 A4
    -- MALONE TUNING -- EUROCODE HFC--BLACK FOREST INDUSTRIES INTERCOOLER--VMR 710S 19"--CTS INTERCOOLER PIPING--CTS TURBO MUFFLER DELETE--P3 GAUGE--STRAFE FRONT SPLITTER--FORGE MOTORSPORTS DV--CUSTOM EXHAUST
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by XtremeXiong View Post
    Hello all,
    Mfg Part #
    4F0973705
    ECS Part #
    ES#393640
    Are you referring to just the metal pins that hold the wires into the female connector? If so, depending on where you purchase from, they are included like the eBay post below. Otherwise, if you know the gauge of the wires, you may be able to use the pins in the IE or ECS links below.
    http://www.ebay.com/itm/VW-4F0973705...-/181712655058
    http://www.performancebyie.com/vw-au...FdBahgodVCgCMA
    https://www.ecstuning.com/b-genuine-...tor/4f0973705/
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Feb 18 2016
    Hampton Roads/VA
    Yes. Thanks so much! My connector totally got melted.
    Quote Originally Posted by bakedziti View Post
    Audi B8 A4
    Nov 01 2012
    Tampa,Florida
    Did you fixed? My got melted too...i need to know how the wires go
    Established Member Two Rings TVP125's Avatar
    Dec 14 2015
    Palm Beach, FL
    pin 1 is green pin 2 is brown pin 3 is black
    12 Audi A4 S-Line
    EURODYNE FrankenTurbo F23L
    K&N Typhoon Intake
    Magnaflow Sport Series 3" Turbo Back Exhaust
    Treadstone TR8L Intercooler
    ST Coilovers
    Active Member Two Rings cdmx's Avatar
    Apr 01 2009
    2004 Audi a4 3.0 Quattro, 2002 toyota 4runner sr5, 1994 bmw 325ic
    Charlotte, NC
    For anyone else who has the issue. I have a 2009 b8 with 1.2mm wires. ECS Tuning sells an aftermarket pin that fits. 1-1.6mm. Will let y'all know how that goes
    2009 AUDI A4 2.0T QUATTRO IBIS WHITE
