Results 1 to 13 of 13
    Senior Member Two Rings jwallace0988's Avatar
    May 16 2016
    None
    Rochester, NY
    Vibration at highway speed (2014 S5)
    Hi guys/girls, I just posted my first welcome post a few minutes ago but wanted some specific attention to my one concern on my today purchased 2014 S5.
    I feel there is an unnatural vibration above 60 mph... I'm not sure how to pin point it but I'll give it a shot.
    You can feel it in the steering wheel, floor boards and shifter. It's not very audible - but almost sounds mechanical in nature if I had to take a stab (like a low hum), It is NOT a violent vibration - but definitely noticeable once you get into the 60 - 70 mph range - like it takes over at that point. As I am new to Audis specifically and the Stronic transmission, is this normal? I plan on contacting the dealer first thing tomorrow as its a fresh purchase to me.
    Dealer put 4 new tires on and did alignment when they acquired the car before sale.
    Clean carfax, 22k miles, no obvious rim damage, Stronic, w/ sports diff.
    Thank you! Any feedback/input is appreciated!
    13' S4 - Ice Silver (DSG, B&O, Carbon Inlays, Black/Magma Leather, Sports Diff) - EPL Stg. 1 ECU w/ DSG tune, Roc Euro Intake, DeAutoKey Full LED interior(white), Red (Front floor), LED Exterior lighting (Turn/Reverse). Eurocode poly mounts, Soundakor DELETE!, Xpipe mod, Carista!
    Past: 12' GTI Autobahn, APR Stage 1, CM FX350 w/ flywheel, Magnaflow CB exhaust :: 06' Scion tC: Full Bolt-ons to turbo build at approx. 300 WHP/TQ on 8-10 psi, Konig After-burners, RL Coils, poly mounts etc.
    Veteran Member Three Rings Audiforumuser's Avatar
    Mar 01 2010
    2010 A4 Avant S-line
    Saskatchewan
    Do you know if the dealer "road force balanced" the wheels? Small imperfections in balance will cause what you're experiencing. Hopefully it's that.
    09 A5 S-line Monza Silver / Incurve IC-S10 20x10.5 / KW H.A.S.
    May 16 2016
    None
    Rochester, NY
    Quote Originally Posted by Audiforumuser View Post
    I'm not sure about the road force balance, would an Audi dealership have that in there shop? Or a speciality shop
    Nov 10 2014
    Apex, NC
    vibration above 60 mph is usually balancing of the wheel issue... vibration at all speeds is usually suspension related
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    May 16 2016
    None
    Rochester, NY
    Visited the dealer today and had a tech ride with me - I drove first, then he drove. During both turns he was able to see what I was talking about and replicate the vibration. He narrowed it down to between 60ish to 75ish when the vibration occurs but after 80 it disappears. We set an appointment up for tomorrow to rebalance the tires and put it on the alignment machine. During the test drive we tried putting it in neutral with it not affecting the vibration at those mentioned speeds. He also tried low speed higher rpm and saw no vibration - making sure it wasn't something engine or transmission related. Since the tires are brand new, hopefully tomorrows visit corrects the issue, I will follow up then!
    Nov 10 2014
    Apex, NC
    no vibration at speed with the car in neutral not a good sign.. that would rule out wheel balancing
    Present:
    Mar 01 2010
    Saskatchewan
    Quote Originally Posted by jwallace0988 View Post
    I think most do now. My dealership has one and the tech always walks me through the electronic print-outs. Pretty cool actually. The machine simulates road forces on the wheel as though it's on the car so can pick out small imperfections that a typical manual machine won't detect.
    Were the tires put on the car when you purchased it or when the Dealer took the car for resale? It's possible that sitting for a prolonged period of time may have flat-spotted the tires enough that you'll feel slight vibration at speed. Typically the tech can balance this out on a Road Force machine to the point that it minimizes or completely eliminates what you're experiencing.
    May 16 2016
    None
    Rochester, NY
    Quote Originally Posted by doug97gxe View Post
    Oops I meant it had no effect on the vibration. Aka it continued the vibration* thanks for the catch!
    Nov 10 2014
    Apex, NC
    Ok then that should be a balancing thing not mechanical
    Sent from my iPhone8s using Tapatalk
    Present:
    May 16 2016
    None
    Rochester, NY
    Yeah definitely hope not, the car was serviced at the correct intervals. Hopefully tomorrows visit clears up the issue!
    Established Member Two Rings sly9's Avatar
    Sep 29 2015
    Columbus,OH
    I have the same problem and sent a post a few days ago. I am finding the road force balance service these days..
    2010 Audi A5 2.0T Premium Plus Ibis White
    APR Stage II | APR Downpipe | H&R Street Performance Coilover
    May 16 2016
    None
    Rochester, NY
    Not quite the update I was expecting to give. What I believed was going to be a superb purchase has now turned into a really really bad time. Thanks for the comments and posts - hopefully I return with another Audi as this one turned out to be WAY more problems then it was worth. Their was about 4K worth of paint issues from previous repairs that they didn't share with me, and they never found the source off the vibration since I pulled the plug once the paint discovery dropped a bomb on my excitement.
    Mar 01 2010
    Saskatchewan
    Shitty man. At least you discovered this early on and got out of the car. Good luck in your search for another one.
    The paint damage is likely related to the shimmy you were experiencing. Probably damaged suspension components from whatever ruined the paint work. You made the right decision.
