    Feb 24 2004
    Minneapolis
    Boost test, am I doing this right?
    Read a few DIY's where you just pump into the intake side of the turbo. Does the throttle plate hold the pressure on the other end? I can't hold pressure that way. Not at all. I hear some fluid moving around somewhere, but I can't hold boost. I don't think I'm even holding enough pressure so that I'd hear a leak.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings Audi_509's Avatar
    May 20 2010
    2008 A4-sold. 2019 A5-sold,: '23 S5
    WA
    I tried doing this a few weeks ago. I'm not sure if I was doing it right. But I thought the rear pvc had to be disconnected and plugged. I also read to remove the oil cap.
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Fail, you need to plug the pcv return line from the turbo. You are just pressurizing the valve cover and it is escaping. See pic, I use shop rags and a wine stop.
    Also, I have been told it is not good to pressure test on the inlet side of the turbo since it can strain the seals. I don't really see it doing that much damage and I do it on the inlet side, but just a thought. So you would test at the IC piping instead.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Der Konig View Post
    Thanks. I wondered about that pipe but thought the check valve in there would hold the boost. You don't block the hose going into the throttle body?
    Jul 09 2009
    Cleveland OH Area
    Quote Originally Posted by mtroxel View Post
    No problem, and no I don't block anything else.
