Results 1 to 14 of 14
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    Electronics, dash, a/c Shut off car still on
    Searched.
    It has happened a couple of times now. 2010 s4 DSG 68k
    The other day went inside the store left the car on with a/c on. Came out 10 minutes.. All power off inside ie. a/c off screen on dash off.
    Turn car off and back on was overheating. Turned heater on leveled out. Electronics shut off so fan stopped cooling.. my guess..
    Anyone experience this ?
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    How's your battery? Not sure how hot it's been in CA but we have been in a damn heat wave of 100 degrees in PA for like two weeks. I've been running my AC non stop even while idle for a 5+ mins while my fiance runs in the store. I know it's adding some stress to the battery for sure . The other night while parked with the AC on, low beam lights on my cluster flickered and I got some dash warnings and the the idle dropped. Popped opened Carista and it said function limitation due to voltage to high. It shut off TPMS, ABS modules, central electronics etc all kinds of crap. Shut the car off and restarted and keep the AC off and it was fine.
    My battery shows bad after I had it scanned at autozone. So It can be a case of going into low power management mode were the car starts shutting off electronics in order to keep running on reserve power. I got a new battery today from the dealer and tossed it in. It's been brutally hot here in PA in the heat wave.
    I swore i read on here if the car is in fact in low power mode, the car will shut off electronics if it sits at idle for 3 mins. I could be wrong. So essentially it will start shutting off electronics in order to keep the car running.
    Oct 30 2013
    Replaced the battery i would say maybe 6 months ago.
    Yea its been 95-100+ for awhile.
    Going to test my battery tomorrow.
    Low power mode sounds terrible if its going to shut off cooling components and overheat the car.
    May 20 2015
    PA
    It's random as well what the car will shut off & its up to the ECU would assume.
    I've read some people have had electronics turn off while driving which can be dangerous if in a intersection and the car decides well you don't need power steering, headlights or abs!
    Mine turned off steering angle sensor, central electronics and tire pressure warning briefly. It didn't fully cut it off really just flickered. I did turn the car off and back on and it was fine. Odd
    Junior Member Two Rings m3sk8r's Avatar
    Jul 30 2009
    Las Vegas, NV
    Just had this happen to me as well a few days ago while I was driving. Everything shut off but engine and let me continue to drive till I got to a parking lot. Let it sit for a few and started it back up and everything was back to normal. Had been driving in 110 degree heat for almost a couple hours when it happened. Scanned it and had a ton of over voltage codes.
    May 20 2015
    PA
    Yup, this heat has been pure hell! Got the same over voltage codes. It's making the car work so much harder and impossible to not have the AC at full blast at all times.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    If I'm not mistaken, if your battery is week the alternator has to work harder to make the extra power needed to run all the accessories when idling. when your moving, your RPM's are higher and that will work well but as soon as you stop (at a light) the alternator has to produce more power at idle causing high voltage issues.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    I just posted this issue last week http://www.audizine.com/forum/showth...-over-voltage?
    I was about to post the solution there but might as well start here. The dealer replaced the voltage regulator. There's actually a TSB for this, 2031145/2. It seems to be a common enough issue to issue a TSB and the same voltage regulator is used across most of the model line (A4, A5, A6, A7, Q5, Q7). Interestingly enough it doesn't explicitly list the S4 but the symptoms are the exactly the same. Maybe they don't list the 'S' variants and just fall under the 'A' line. Here's the repair order:
    So far it hasn't happened again and it's been pretty hot and humid here. Here's the TSB: http://www.esghotwire.com/bulletins/...TC_Present.pdf
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    May 20 2015
    PA
    That's interesting only time my S5 has ever done this during this brutal heat wave. My battery did show up " bad" via auto zones scanner as well.
    Oct 30 2013
    Last night happened again. Sitting at a drive thru no a/c on 85 deg outside dash just went black.
    Gonna take it to a shop friday and see what codes i pull.
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    car is telling you that fast food is bad for you!
    May 20 2015
    PA
    Mine seems to be good since I replaced my battery. Longest I've let it sit idle is about 3-4 mins since battery replacement so not the best stress test. However it's 95-100 degrees here the last week.
    Oct 30 2013
    Tested the charging system.
    First test Voltage regulator failed.
    tested multiple times after that and passed.
    Car was sitting before test.
    If the car is charging at 18v when regulator acts up its killing the battery over charging it.
    Still haven't pulled codes..
    Gonna take it to a buddies shop and throw it on his fancy strap on scanner tomorrow. I mean snap on
    Jul 12 2004
    Audi%20B5%20S4
    Miami, FL
    Any updates ???
    2001 S4|Nogaro|Sport|Stage 3|BWK04|BBTune|1000cc|Walbro450|KWv2|Volk LE37|034|18Z
    2000 S4 2.7Tqm Brilliant Black|Sport Int|Stage 3|BWK04|VAST|SSAC|TrackSports|MORR 19x8.5|034|BBK
    2011 B8 S4 Ibis White/Black DSG|APR Stage 2
    2000 A4 1.8tqm Brilliant Black|Frankenturbo F21|Motoza|Borla|Godspeed|Carbonio|Enkei|H&R|Bilst ein|034
    2000 S4 2.7Tqm Brilliant Black|Stage 2+|APR|Borla|Bilstein|Eibach|BBS
    1997 A4 1.8tqm Sable Brown|MTM Stage 3|Koni|Eibach|BillyBoat|
