Results 1 to 6 of 6
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Which tire size to use...
    I have b8 a4 sport package wheels. I believe they are 18x8 et47. Will I be able to run 245 40 18 tires? I'm currently running 225 40 18 tires and they look a little stretched. My car is lowered on eibach pro kit springs and koni sport shocks.
    Aug 10 2012
    Sylvania OH
    My current setup is 18x9 et 52 S6 wheels with 255/40 tires. I'm lowered similarly with H&R/Bilstein, but I do have 10mm front and 15mm rear spacers. I don't have any problems with fit or rubbing.
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    I run 235/40 18 ET 43 for summer/daily. 245/40 18 ET 35 for my winter tires and 245/40 18 ET 35 for my track tires. All fit with no issues.
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I'm on b6 S4 18". 45et 10mm front 15mm rears 245/40/18 lowered on koni coilovers and my fitment a clear. No rubbing I'm not as low as I could be. But it's clear no rubbing no issues. Camber is 2.5 on all 4 corners.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Im on AMG C63 wheels 245/35/r19 fronts stock space, 255/35/r19 rears 10mm spacers and 40mm lugs. I am lowered and only rub a tiny bit if I hit a horrible bump. No clue on the offset lol.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Something to keep in mind is that not all tire widths are created equal. May sound odd since they are a measured value, but it is true that some run "wide" opposed to others.
    Take for example, I used to run Pilot Sport 2's in 235/40/18 with no issues, autox didn't even cause rubbing. Switched to super sports in the same dimensions and am having rubbing issues even on on ramps if I take them hard enough. Just something to keep in mind if you think it might be close.
    You should be able to run most anything with that milder set up without rubbing though.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
