2000 Audi S4 - 121K miles
2000 Audi S4 - 121K miles (Mileage will go up as it is my Daily)
Clean Title - In hand
Stasis Rebuilt Cryo Treated Trans - Installed @ 62228 miles
K03 Hybrid Turbos Installed @ 104K - @20K miles on turbos Total
Timing Belt/Water pump, T-Stat, Bearings, Tensioner, Snub & Motor Mounts (ECS tuning mounts), O2 Sensors, Valve Cover Gaskets, Cam Seals, Cam Lifter Gaskets, Oil pan Gasket, Drop in air filter, Front Crankshaft seal, spark plugs, Fuel filter, Cam Chain Tensioner Gasket, Accessory belt Tensioner @ 104K
Front CV axle rebuilt @ 104K
Southbend Stage 2 Daily Clutch Installed @ 104K
Fidanza LWFW
Rear Driver Side window assembly fixed @ 104K
Slave Cylinder Replaced @ 104K
Stern Transmission mounts, ECS Diff mount, OEM driveshaft, AWE Drivetrain Stabilizer, OEM Diverter Valves @ 114K
Work Done by the AMAZING Justin Ballou - Best quality work at the best price
SSAC Turbo Back Exhaust
2.5 inch BiPipes
Tuned by Wicked Motorsports
18 inch R8 Replica Wheels
New Tires - BFG Comp Sprt 2
Tinted windows all around including windshield
Interior in spectacular condition - Front seats were rewrapped recently
Carbon fiber wrapped interior trim
Carbon Fiber Mirror Caps
Rebuilt Cluster
Lowered on Tein Springs
Greddy Boost gauge
Innovate AFR gauge (needs to be plugged back in)
Bad:
Front door speakers need replaced
Windshield Washer Fluid Reservoir leaks - needs replaced or sealed
Rocks chips, Scratches, a few dings, the kind of wear you would expect from a 16 year old car
Previous owner was in Arizona - Some of the paint is oxidized due to being left in the sun. Mostly the roof and a small part of the trunk
It's a beautiful car with Low Miles, a relatively new transmission with all major service done recently. Make me an offer - 1(909)-293-9663 or [email protected]
List Date: 7/25/2016
For more info, click here to view the original listing: 2000 Audi S4 - 121K miles
This item is no longer available.
