The one that's all crunched up.
I will explain what happened later ;)
For orientation you can see the wheel in the one picture that is the front passenger side wheel the line that is in good condition is on the outside of the car. The crunched up Line is towards the middle of the car.
The car idles just fine as is but I'm going to have to splice in a repair to this line regardless.
Are the lines on these cars plastic or metal ones I cut into them?
If it is the supply line when I cut it open is the entire fuel tank going to drain out?
Same question if it is the return line is everything going to drain out?
Bad day so far, thanks in advance.
