Results 1 to 3 of 3
    Oct 05 2012
    Tempe,AZ
    Mystery Plug/Grommet
    Please help me determine what the part number is for the following:
    2006 S4 Avant Right Front Inner Fender/Unibody - where Black painted fuel line transitions from wheel well into engine compartment.
    This piece is approx. 1 1/4" wide by 2 3/4" tall - somewhat rectangular in shape, has radius corners And appears to "push-into" a similar shaped opening in the uni-body - nesting around the black fuel line - such that when in place - the upper portion of fuel line is covered and the lower portion is exposed to the wheel well.
    If I knew how to post a photo (from my vehicle) I would.
    I had a tire tread delamination event recently - of the right front tire - striping off a 1 1/2" wide by say 30" long piece (or pieces) of tread - at +/- 85 mph... a little entertaining...
    So, far, Audi Dealer and Collision sources - seem unable to ID part.
    Please advise if you have info.
    Thank you
    WileyBrill
    Oct 05 2012
    Tempe,AZ
    So, none of you out there seemed to know - or are able to provide any helpful info on this part (since no replies).
    Here is the answer: Thanks to extra diligence on the part of a Dealership Parts Department person(s) - the answer is : A Foam Body Seal # 8EO - 201 -196 - B Seal
    It is associated with an A6 fuel line assembly for: "cold country" distribution - (like North America)
    Though it is not found in an Audi A4 parts search - investigation of other A4/S4 vehicles - yielded the part, still in place an the valid part number.
    Mine, had to be ordered from Audi-Germany and is ridiculously priced - but it is an OEM replacement of the missing part.
    Thank you
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Thanks for closing the loop! Glad to hear you got everything sorted.
    Sent from my VS985 4G using Tapatalk
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
