Results 1 to 11 of 11
Thread: car overheating
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    car overheating
    had the AC on full blast due to the 85 degree weather here and noticed that the AC started to feel warm. i then noticed the coolant gauge on the left and the needle was steadily climbing towards the H. i pulled over immediately
    are these symptoms of a thermostat failure? i know there are a million threads like this and i've already searched, but my car is sitting in a random parking lot and time isn't really on my side
    if this IS the thermostat, has audi done anything to cover it? i read a few old threads about a RVU but the dealer said there is nothing for my VIN
    thanks
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Apr 05 2016
    Portland, OR
    I can't remember if these are covered but, I imagine you could convince them to cover it.
    It is likely the thermostat. You could either get it towed into the shop or drive there with the heat blasting and closely watch the gauge.
    Geoff
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by KRp220 View Post
    thanks
    Yep, agree that the T-stat is toast, failed shut. Is this the first T-stat for your car ( 2010 )?
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Aug 23 2011
    NH
    Quote Originally Posted by sacandagaD View Post
    not 100% sure... its been a while since i've looked at the car fax (bought it used) but i thought i had a metal thermostat when i looked in the gine bay when i bought it... or am i thinking of the water pump?
    Jul 02 2013
    Yes, water pump was a problem on early cars B8 2010/11. T-stat is still plastic prongs that break as far as I know. Definitely Achilles heel and costly to fix out of warranty at dealer. What a crime that they know it.
    Aug 23 2011
    NH
    any idea what the cost is like?
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    85 degree weather????
    i pray for those temps.
    Jul 02 2013
    $ 750-1200 depending on your dealer. Indy shop should definitely be less. There might also be DIY out here somewhere if you are so inclined, supercharger has to come off.
    Junior Member Two Rings SoNHS4's Avatar
    Apr 25 2011
    '04 Ducati S4R; '14 A5 Cab
    Richmond, VA
    Just had same problem with my 2011... High temp warning on Friday night. Drove home 8 miles with heat on. Next day, catastrophic engine failure. Interested to see how this goes for you.
    "If you're gonna be dumb, you've gotta be tough."
    2011 S4 Premium Plus | Quartz Gray | Black Nappa | Carbon Atlas | Sport Rear Diff | B&O | Nav Plus | 19" VMR V710's | Adam's Rotors | RS-style grille
    [Misc: Carbon S/C Badges, Xenonmatch Fog Light Bulbs, Underseat Drawer, Warning Triangle, Weathertech mats...]
    Mar 21 2015
    ^ Wow that blows, I take it your out of warranty?
    Apr 25 2011
    Richmond, VA
    120,000 miles..... Yes sir.
