Results 1 to 9 of 9
    Veteran Member Four Rings MerlinS3's Avatar
    Aug 04 2010
    2023 SQ7, 2021 Exclusive SQ5, 2022 Exclusive RS6
    Frisco, Tx
    Tuning and spark plugs
    Getting my car tuned next week and had a question in regards to spark plugs and coil packs..
    I know on the MK6 chassis upgrading the plugs/coil packs when going stage 2 was suggested for best performance, now my question is should I upgrade my stock plugs before flashing the car or is it not necessary on these motors?
    I read on Vortex a lot of guys with MK7 R’s are upgrading plugs when doing stage 2, so curious on this.
    Thanks in advice for my dumb question
    FYI,
    I will be flashing the United Motorsports Red file onto the vehicle
    [CENTER]CURRENT | RS6 Avant | Audi Exclusive | Uni Stage 2
    CURRENT | 2021 SQ5 Prestige | Exclusive Paint | Sport Exhaust | Black Optic | Dynamic Steering | Sport Package | BC Forged
    CURRENT | 2023 SQ7 | Stealth PPF | Lowered |
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    I changed out my plugs to Denso. Apr recommends it with stage 2. Also I read that they are a tad cooler than OEM so it is better. I was only with JB1 but I too am considering Stage 2 with UNi. As far as coil packs, I did some research and yes it is good to upgrade but only if you are going bigger turbo.
    Aug 04 2010
    Frisco, Tx
    Quote Originally Posted by jiannu View Post
    Which Denso plugs did you get?
    I think I might just do plugs and coil packs as a precaution to not run into any issues, as for coil packs do the red top coils fit in these or is there a specific coil pack to upgrade too…
    The plugs have to be gapped to .24 correct?
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    ... I read that they are a tad cooler than OEM so it is better
    The numbers on the plug will indicate whether they are cooler, not the maker, so it would depend what plugs you put in. You're not really "upgrading" plugs so much as running a colder temperature. Depending on your tune, you might want to also consider running a different gap.
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I am running the Denso IKH24 Iridium Power Spark Plugs. I installed them when I was at Stage 1. Still running them for Stage 2. I got the 4 pack on Amazon for around $32.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Aug 04 2010
    Frisco, Tx
    Quote Originally Posted by MacFady View Post
    I spoke with UM and they suggested to do 2 cycles cooler plugs then what the oem is for the red file tune I am installing
    Mar 23 2016
    Ontario,Canada
    Sorry but I too am running Denso IKH24 which do run a tad cooler than OEM according to the number...
    Aug 10 2011
    330i ZHP
    OP, sounds like you have your answer. Just remember the higher the number (24) the colder if your comparing your plugs. While the general rule applies across the board, the numbers used vary by manufacturer. The NGK ***8** for example is the same temp as your Denso 24.
    Aug 04 2010
    Frisco, Tx
    thank you for that info, probably going to order the Denso or ngk tonight
    https://www.amazon.com/NGK-R7437-9-R...0D0NQYB4EGX47G
    or these
    https://www.amazon.com/Denso-IKH27-I...5F0HYV14W85EEF
    any light on the Coil packs and what is out there for replacement/upgrades?
