Results 1 to 6 of 6
    Established Member Two Rings q2quest's Avatar
    Jan 22 2009
    Santa Rosa, CA
    Power Steering Hose Question. What is this?
    In an earlier post I described how the return hose burst on my 3.0. Below is a photo of the hose that goes from the reservoir to the PS cooler pipe.
    I was curious about the two factory looking clamps and began to investigate.
    I cut open the hose and removed these two metal pieces which have a much smaller diameter hole inside. They look like flow restrictors. One of them has some electrical tape rolled up and shoved inside the hole, essentially blocking all the flow. What in the world? Obviously a previous owner did this, but for what purpose? Do these metal things look familiar to anyone? Can anyone explain why someone might have done this? Perhaps this is why the steering always felt stiff?
    2018 A6 3.0T Competition Package, Daytona Gray, Jackal Motorsports Stage 2, 15mm wheel spacers
    Aug 19 2013
    minnesota
    Someone fixed the failure design stock power steering hoses at the oil cooler. They must have accidentally got some electrical tape in there, I can't imagine they did it on purpose. I did the exact same thing with larger and different hose barbs. I also sealed the threaded connections on them with red Loctite. It fixed my power steering leak in my power steering cooler for a fraction of the price of the OEM hose. Total cost was like 10 bucks or something, whatever you do, whoever else may read this some day. Do not use vacuum hose! Always use fuel hose! Vacuum hose will sweat and leak like crazy. Fuel hose will work perfectly. I used screw down hose clamps instead of the crimp Style.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Jan 22 2009
    Santa Rosa, CA
    After doing much reading I see now that those restrictors are stock Audi pieces. However, someone definitely rolled up a piece of electrical tape and shoved it in there. It was in there tight and was no accident. Strange, though because the factory crimp clamps were still in place and looked like they had never been tampered with.
    Aug 19 2013
    minnesota
    Quote Originally Posted by q2quest View Post
    Odd
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Is is possible that the tape is actually a chunk of the hoses inner wall that seperated off?
    Jan 22 2009
    Santa Rosa, CA
    Quote Originally Posted by Kevin C View Post
    I don't see how. It looks exactly like electrical tape carefully rolled up and shoved into the hole.
    I just received my new hose and it did not come with any restrictors. Should I swap over the ones I have or run it without?
