Results 1 to 4 of 4
    Nov 02 2013
    New Castle, DE
    Which way should the radiator and AC fans be moving air?
    '04 B6 A4 1.8T 6MT Ultrasport
    Just did the timing belt, both fans and FCM while in service positon. Both fans died and took out the FCM. The new FCM with the AG suffix runs both fans on high when the AC is on. Ok, I found that confirmed in a thread or two.
    But, I happened to notice that it feels as if the fans are blowing out through the grille. Is this correct?
    The fan/shroud unit that I purchased is an aftermarket unit that is supposed to fit B6 and B7. Did the B7 have the colors opposite of the B6 from the FCM?
    Thanks.
    Apr 17 2016
    kc
    Dont know the wire colors on b7. On my b6 is green, yellow, purple and red , and both fans should be pulling air in, not blowing out.
    Aug 26 2005
    To reverse the fan rotation direction, swap the two wires to the fan motor, +/- > -/+.
    Vorsprung durch Technik
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I would try a smoke test to make sure they are wired wrong.
