Results 1 to 3 of 3
    Feb 17 2016
    Grand rapids michigan
    Power windows and sunroof help
    Was rolling up windows and all of a sudden they stopped amd now only way to use windows is with key in door lock any ideas please help me!
    Established Member Two Rings drift4's Avatar
    Aug 15 2015
    BMW 335I / BMW 533I EURO CONVERSION
    Fairfax Virginia
    Had the exact problem, after checking
    Relays , switches, found 5 amp
    Fuse for central locking unit blown.
    Replaced it and the switches light back up again
    Senior Member Two Rings freekonwheelz1's Avatar
    Apr 07 2014
    1995 Mazda Miata 1.8 daily, 1965 C10 SWB gift
    Oklahoma
    Quote Originally Posted by troyritsema View Post
    i had the same problem and occasionally they would roll themselves all the way down and not roll back up again. one day one of my doors burned up (literally) so i put the fire out on the side of the highway and upon further inspection one of the wires shorted to the door frame so id pull your door cards and check all the wiring. if it isnt that then check your central locking pump in the trunk and if its getting warm while the key is on then somewhere is a short. i never actually blew any fuses either so you have to be careful with these window problems.
    obviously check fuses first. then wiring, then pump. if nothing else youll at least have a better peace of mind than i had.
    2001 A4 TQM. AWM motor - TR11 Intercooler, ECS Snub Mount, RA4 240mm clutch kit with lightweight flywheel, SAI delete, PCV delete with catch-can install, Borla turbobackFS, Forge 007 DV, Raceland Coilovers, weighted shift knob, x2 10" clarion subs, 0/1 awg power and ground, pioneer door and deck speakers, clarion 6.3" headunit, HX35 t3 turbo (installing), E85 conversion (installing), AEB head (to be built)
