Results 1 to 23 of 23
    Apr 14 2016
    Austin Texas
    EPL is the TRUTH
    Cut a 12.71 last night at 110.5 MPH in 3250 DA. Stage one 93 octane/TCU tune with ECS CF intake. I know it's not near any records per se, but I am EXTREMELY happy with the car, tune, and given track conditions.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    Stock cooling?
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Apr 14 2016
    Austin Texas
    Yes, stock cooling. Also, FWIW had a splash of 104 in the tank.
    Feb 20 2012
    e90 M3
    NH
    Very nice time/mph given conditions.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Lol what's a splash.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Apr 14 2016
    Austin Texas
    2 gallons with probably...5 gallons of 93 in the tank
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Nice eta/mph given the DA.
    '18 S5 - BBS / EPL
    Feb 20 2012
    e90 M3
    NH
    Which DSG file are you using? Does it short shift if you use launch control?
    Nov 11 2012
    arlington, va
    Given that, you should be about 12.4 in normal conditions. Haven't been able to get out to track to test my car out.
    2014 S4 Estoril Blue Prestige - Mods : AFE Filter w/ Eurocode Inlet hose.
    Apr 14 2016
    Austin Texas
    It will be faster than 12.4 in good air. I'm quite confident of that.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Nice Work!
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Quote Originally Posted by adamtc4 View Post
    This. I think 12.9 is stock, right?
    Apr 14 2016
    Austin Texas
    In perfect conditions or almost therein. Possibly you could run that. Last night was the opposite end of the spectrum. 70-85% humidity, 620ft elevation track, and 99-86 degrees air temp. DA started at 3950 and eventually dropped to about 3300ft. Interestingly, All 3 Audis there picked up 3/10th over a 6-700ft drop in DA. I don't expect that will fully extrapolate, but, there is absolutely more there than another 3/10 in good air.
    Sent from my Venue 8 7840 using Tapatalk
    Jun 12 2015
    CA
    Those DAs are bananas.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Oh I'll show you bananas
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Apr 14 2016
    Austin Texas
    I mean, it's not Bandimere in summer bad, but they're pretty bad :-)
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Quote Originally Posted by chet.rowles View Post
    pretty important tidbit but still good time regardless w/ the southern heat which I'd argue is the worst in the united states especially w the humidity especially in florida where it is like sticky salty thick humidity. but 85 degrees san antonio is sounding pretty nice. must of been a night run? i wish we at 85 degrees in tennessee.
    Deactivated Four Rings
    Jun 23 2011
    I don't know where some of these tracks record the temps, but a few weeks ago at Waterfest is was just awful hot and I lived in and worked outside in FL for years so being up north now doesn't bother me that much. But at waterfest it was miserable and the track temp had a high of 91. That must be a temp gauge on the roof because on the ground it was 95-100 easy. Needless to say it is a great time given the conditions. As no one is breaking any records this time of year. I wish more people would post their times good or bad so others can see.
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Great results given the conditions! Generally speaking 110-111 is a "reasonable" trap speed for stage 1 in ~1000 foot DA... its borderline unreal that you pulled that off at ~3500 ft. Look at the old 1/4 mile thread when you have a second....there cars with similar results with -2000 feet less DA!
    Thanks for positng
    Quote Originally Posted by Thurston View Post
    With out tuning, the gas would have effected times very little. He may have retained a little timing in 3rd/4th gear, but your talking a handful of horse power.
    Apr 14 2016
    Austin Texas
    Yes, that run was after midnight, it had cooled down to 86 degrees. My blended octane was probably 95-96. It's not immaterial, but the car didn't 'feel' quicker than it does on the street with straight 93.
    Apr 27 2015
    canada
    good to know, i was sort of wondering how the butt dyno felt after the splash but it's good to know based on what tony said, i can save some money in the future not filling w race gas unless i get the tune tweaked for it.
    Apr 14 2016
    Austin Texas
    Quote Originally Posted by Chris@EPL View Post
    It's a very valid point Chris. The track surface was still easily over 100 at that point, and 'ground temp' was easily in the 90s.
    Apr 14 2016
    Austin Texas
    Quote Originally Posted by Tony@EPL View Post
    Thanks for positng
    Absolutely! I knew the updated stage 1 tune was stronger, but certainly did not have this level of expectation. In fact I was pretty certain given the significantly worse conditions, that I would not improve upon my May track times.
