Results 1 to 19 of 19
Thread: Carbonio Intake
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Carbonio Intake/APR
    Alright, I've read just about every thread out there on the web on intakes.
    I want to make the jump (I think, as I doubt intake will void a powertrain warranty/flag a TD1).
    I've studied up, watched install videos and read pdf's on each (APR/Carbonio, Roc-Euro, USP) intake systems.
    I really like the concept of the Carbonio that is still "in the box" and not just sitting in the engine bay separated by a heat shield. And I don't want a ton of supercharger whine that the R-E makes.
    I'm a bit hesitant given my history of engine failure, and prior to that had a MAF failure linked to an aFe pro-dry filter. It took it 12 days to burn the MAF up after filter install in stock box and was about a $600 fix.
    So I've decided on the Carbonio. And if I do that, I'm going to do the stage II carbon back pipe as well.
    My questions are this:
    1- does the damn thing really fit? (most say yes, some say no) APR site lists it for SQ5 with a special note saying it doesn't fit in fine print.
    2- I've never had to care for an oiled filter before (the reason I went with pro dry one before) and I'm afraid I'll over oil it.
    Does it come pre-oiled out of the box? I know it's washable. But I could see me buying a new one when changing it potentially. What's the recommendation for cleaning it (mileage wise) or replacing?
    3- does anyone else run this setup on their Q5/SQ5 currently? Any issues whatsoever?
    At some point near end of warranty period, I'll go full stage 2 prob, so this will be the precursor to that.
    Comments are welcomed. I'm still thinking about it currently.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Mar 14 2012
    Ona, WV
    Also, what about the S-Flo from AWE? Anyone know if it fits?
    http://www.awe-tuning.com/awe-tuning...-intake-system
    It's a box system as well it looks like.
    Current Stable:
    Past Whips:
    Jan 08 2016
    Los Angeles, California
    Quote Originally Posted by ThunderDent View Post
    I'm very skeptical of any gains with any aftermarket intake kit. I just replaced the factory filter with the stock replacement. The aftermarket set ups are virtually identical to the stock set up. The only difference is the aftermarket set ups removing the stock sound baffles. I'd be surprised if removing the baffles created more than a few horsepower due to more linear air flow. I'd say aftermarket set ups are primarily for more sound, not power.
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    If I were to do a full intake, I would def do the full ECS one
    Jun 12 2015
    CA
    The carbonio doesn't fit the facelift S/Q5s very well. I bought one and decided not to use it based on the poor fitment.
    Oct 04 2014
    Mission Viejo, CA
    Get one of these and call it a day. Maybe a aftermarket air filter too.
    https://store.034motorsport.com/audi-q5-sq5-3-0-tfsi-throttle-body-inlet-hose-high-flow-silicone.html
    If want to dress it up the AWE carbon cover looks nice but costs a bundle. I think it's just a New lid to the oem box.
    Oct 04 2014
    Mission Viejo, CA
    Oh and the 034 inlet pipe hose makes no more sound than stock.
    Mar 14 2012
    Ona, WV
    Might be a thought there.
    I'm still on the fence between oiled intake vs stock.
    I do like the dress up carbon of the AWE though, I'm be lying if I didn't.
    Advantages to the 034 hose vs the AWE one?
    Current Stable:
    Past Whips:
    Mar 14 2012
    Ona, WV
    Quote Originally Posted by colby7 View Post
    Good to know. Thank you for that info.
    May be going 034 hose + awe cf box.
    Current Stable:
    Past Whips:
    Mar 14 2012
    Ona, WV
    Just ordered the 034 inlet hose & going to pick up the carbon goods from AWE and run OEM filter.
    Done! Waaaay to worried about oiling the other filters.
    I appreciate all the feedback. Thanks everyone.
    Current Stable:
    Past Whips:
    Senior Member Three Rings turrifik's Avatar
    Mar 08 2015
    Is there an aftermarket filter element worth trying to replace OEM? I have the 034 hose, but will probably keep the OEM box unless some real improvement is to be had.
    Mar 14 2012
    Ona, WV
    After researching the crap out of this, I don't really think so.
    Some here are running USP (I think @S-Fore does).
    That one and the Roc-Euro are both open concept systems that eliminates the box completely and just separates the filter (oiled) from the engine with a heat shield.
    I want the box myself. So I was down to Carbonio (APR) vs S-Flo (AWE)
    APR has fitment issues apparently, so I chose the 034 hose (as its specifically fit for the Q5/SQ5, and will be dressing up the box but using the stock filter, as that is an option with the AWE box.
    It's worth it to me for engine compartment.
    Check fitment here.
    http://www.awe-tuning.com/media/pdf/...Flo_carbon.pdf
    Current Stable:
    Past Whips:
    Sep 17 2007
    Carbonio Intake
    I run a modded oem airbox with an EC filter and 034 tube. I ran the EC tube from my S4 but the angle is off slightly and I had it really clamped down on the airbox. So, I spent the money on the 034 one for perfect fitment. The EC tube is actually better constructed IMO. Anyway, does the job, but as I said above, I'd do the ECS intake if I did a whole new one. If I keep the car, I may.
    Mar 14 2012
    Ona, WV
    https://www.ecstuning.com/ES3098755/...FQEHaQodorIPmw
    Link for those interested.
    Thanks for the input @S-Fore
    Current Stable:
    Past Whips:
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Sounds like you've made up your mind already, but a few random notes regarding what's been discussed...
    - It seems a lot of the intakes have a slight fitment problem with the S/Q5 based on some fundamental difference with the S4/S5. The heat shield doesn't line up/mount properly, so anything that uses those stock mount locations will probably be slightly off. Roc-euro has a special bracket that they supply to fix the issue, but I wasn't too crazy about it.
    - 2 things I don't like about RE: the intake tube is a steel pipe welded together (a powder coated exhaust pipe) and the bracket they supplied for the heat shield looked like it was made in high school shop class (welded steel again). The steel tube I'm sure has some serious acoustic resonance and probably why most consider it the loudest. It also has a high thermal mass and is going to transfer more heat to the incoming air (maybe not significant but unnecessary). As for the heat shield bracket, I wouldn't put it on any nice vehicle I own. Both of these piece should be aluminum...(or plastic/rubber/silicon for the tube). The nail in the coffin for me was the wire tie used to secure the breather hose and filter. As an engineer, I just don't like RE's approach to these intake kits.
    - The CTS intake has a mandrel bent aluminum tube (like just about every other aftermarket intake) and a legit little aluminum bracket for the breather hose. They could take a page out of RE's book and make a heat shield bracket, but I can't imagine the S/Q5 intake market is big enough to warrant such a thing. I simply came up with my own mounting solution for the CTS heat shield, which also raises the shield up a bit and gets it closer to actually making contact with the hood. The parts they provide in their kit met my approval, so that's what I run.
    - I've read a couple credible posts that the open air elements see more gains than the box...regardless of little to no true heat shielding with the open air. If you don't like the amount of heat it sees (I don't either), apparently it's still better than being limited to a confined space surrounding the element. With that said, going with the s-flow filter, 034 tube, and modding the airbox probably accomplishes similar gains and is the cheapest option. I would definitely modify the box based on what I've read though. I think I remember people logging higher boosts with the open air element too.
    - No need to worry about a TD1. Although they could easily give you one for having an intake, just spend the 15 min to swap back to stock before going in, and it's a moot issue.
    - The 3.0T doesn't have a MAF, so the oiled filter is a moot issue as well.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Feb 21 2016
    '07 CBR1000RR
    PA
    Quote Originally Posted by Pittdawg View Post
    I'm pretty sure most tuners have seen a small
    but very noticeable gain from an intake on the 3.0t. Some have even published the results, and others have discussed it on the forum. I'll reiterate what I said in the other post- I even think there's some measurable improvement that can be seen with simple VCDS logs. No, an intake isn't something you're going to notice in the butt dyno, but I certainly don't think it's to be overlooked if you want to squeeze all the easy (and fun) power out of this platform.
    Instagram: @bg.sq5
    May 27 2016
    Atlanta
    My results on the intake experiments, so far: I could not get reliable ship dates or returned phone calls from Roc Euro, so I shopped around some more and discovered the CTS system at Ecs tuning, AWE, APR, and some others. The carbonio option from APR doesn't fit, the AWE is pricey, but seems like an option for those wanting less noise, for probably less gains, and the ECS option. Well, I went with the ECS option and really like the gains, the noise levels (so far), the build quality, but the intake hose being metal didn't seem like the best choice due to heat. I ordered and installed the 034 silicone hose and got gains that have been setting off codes. Had my shop dial back the tune (I'm stage 2 with custom tune) to prevent the engine codes, and it's running well. They believe the extra air flow may have stripped the actuator in the throttle body slightly, because it's made of plastic and they break often, i'm told. It's holding for the time being. I think the 034 house may actually be a larger diameter than the metal one the came with the ECS. I'll have to inspect closer.
    Sent from my SM-T813 using Tapatalk
    Aug 06 2015
    Chicago
    Use the 034 inlet hose with a Dryflow filter and open up the oem intake housing. More flow than you will need even with stage 2.
    Oct 26 2015
    Norman/OK
    After doing the same research on our SQ5 I went with the 034 intake tube, AFE S-Flo filter and modified the stock airbox. Gains were very noticeable after those rounds of mods. The poster who did the write up on modifying the stock airbox used a bunch of testing equipment to validate his findings. In the end the stock airbox modified will allow an additional 1psi of boost under WOT. Took me maybe an hour to modify the airbox and put everything back together.
