Need help 05 s4 econ light on I think there are 3 reasons y low charge/ bad pressure sensor bad climate control I charged it jumped ac compressor it engaged had cold air as long as I had 12 v to cooling fan I tested both fans they work with 12 volts do I have a few questions will the econ light go out if the fans aren't working what tells the ac compressor to engage where does the ac compressor get its power from if I can get the econ light off would I be able to run a duel fan controller with ac over ride and the fans would be triggered by a temp probe that either attaches to the radiator or a bolt on the engine also I check every fuse tested every relay was a little confused by the 5 and 6 pin ones checked grounds I should also note that I have power 6 volts on the ac fan right before the fcm and 12 volts I think with ignition on or off at the plug before the radiator fcm any help would be greatly appreciated
