    Jul 23 2016
    Birmingham
    Start Stop and key not recognised issue, a6 c7 2013 63
    Hello
    My car was water damaged since then I have issue with keys. They always display message
    "Keys not recognised, hold back of the keys against marked area"
    Second issue is start stop does not work
    I have taken the car to Listers Audi and as per their diagnostics no faults found. I am pretty sure it's some module which is not working fully but not showing faults either but does any one knows what modules control them so I can buy n replace this module ?
    Thanks
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Not to be Captain Obvious here but....have you tried replacing the batteries in key fob?
    Jul 23 2016
    Birmingham
    Yes the batteries have been changed. thats the only thing Audi Suggested and then changed batteries on keys and also reprogrammed them. Audi carried out Deep Diagnostics and nothing came up.
    Mar 29 2014
    Hampshire, UK
    Don't know if this helps you or not....
    http://etka.cc/audi/part_single/cata.../274652/lang/e
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    Does your passive entry work?
    From either side of the car including trunk?
    If above answer is yes, I would be checking center console antenna, somewhere below cup holder.
    if the answer is no, I would be checking passive entry electronics. For C7 passive entry/start electronics is inside bcm, so might need new BCM.
    Sent from my keyfob
    '23 Tesla Model X | '17 Ducati Supersport S
